Author Topic: Boat Speed for most precise recording  (Read 5367 times)
« on: May 18, 2012, 09:31:01 AM »
OK you side-imaging gurus out there.
I already know that you should match your chart speed to
your boat speed in MPH when using side-imaging.
But, to get the most precise, most detailed recordings:
Is it better to go .5 MPH or 5 MPH, and why?
« Last Edit: May 18, 2012, 09:32:20 AM by ITGEEK »
Offline xSilmarilSx
  • Software: 6.250 - 5.320
Re: Boat Speed for most precise recording
« Reply #1 on: May 18, 2012, 12:18:20 PM »
From my calculations, that you can find here :
http://forums.sideimagingsoft.com/index.php?topic=4047.0
Around 1-2mph. Chart speed irrelevant if you record the data. But I keep it around 5
This week-end I will recheck the ping rate of the unit with MAX depth setted correctly,
which will boost the speed a little.
« Reply #2 on: May 18, 2012, 12:32:15 PM »
XSilmarilSx:
I did an SI recording once with the Chart Speed set at 10 (Max).
I then did another recording with the Chart Speed set at 2.
Both times I was going at exactly 2mph.
While viewing in Humviewer, I could tell that the second recording was
much clearer than the first.  I could see the segment/splice lines in the first recording,
but they were much better blended in the second recording.
So, I do think that chart speed (in relation to boat speed) while recording does
matter a lot.
Offline xSilmarilSx
« Reply #3 on: May 18, 2012, 03:35:03 PM »
If you use HumViewer, the chart speed is important when you review your data.
Me, I use DrDepth SideScan and it shows the SI data in relative with the boat speed.
So the image is never stretched or compressed.
Last post January 17, 2010, 12:31:04 AM
Last post April 17, 2020, 05:13:39 PM
by Philip Brown
Last post August 05, 2015, 08:55:35 PM
Last post June 17, 2016, 04:16:13 PM
by Gimp
Last post July 06, 2016, 11:23:50 PM
by Conrad_Turbo
