Author Topic: 597ci HD DI combo. What am I seeing here?  (Read 14472 times)
Offline massillonbuckeye
  • Unit(s): Onix 8nt SI, 788, AC Pro, LM Great Lakes
  • Accessories: Terrova/I-Pilot Link
« on: May 16, 2012, 09:27:42 PM »
Heya guys!  New here!  Love the forum and all the great pics..  Already contemplating a tow fish heh.  Couple questions about this new to me Humminbird.  What do you think about these shots?  Tons of garbage there in those two shots. Any opinions on these?  Thank you!
Going too fast?
« Last Edit: May 16, 2012, 09:28:48 PM by massillonbuckeye »
Offline newkid4si
  • Unit(s): 998c si
  • Software: v 5.70
Re: 597ci HD DI combo. What am I seeing here?
« Reply #1 on: May 16, 2012, 10:19:38 PM »
massillonbuckeye
     In the second image, where you are west of the launch and north of the bridge, you might want to lower the sensitivity some.
     The red and yellow marks from 8' to 12' are probably fish hidden in the noise.
     In the third image, I would guess another sonar was running nearby.
             Mike
« Reply #2 on: May 16, 2012, 10:24:59 PM »
How "sensitive" is the sensitivity?   may have adjusted it one or two points, but I know I didn't make any radical adjustments.  You think just a little extra would do that?  I seem to remember the "DI enhance" setting only making all those marks a little less evident, although still there.  That was my first thought, the sensitivity..  It didn't remove all those marks though.  That lake is 60 feet at its deepest.  I'm usually in 40 or less.  I'm headed out friday or saturday and I'll play with it some more.  Thanks for the reply.
Offline newkid4si
  • Unit(s): 998c si
  • Software: v 5.70
« Reply #3 on: May 16, 2012, 10:34:58 PM »
massillonbuckeye
      That's one of the best ways to learn the unit--- spend time on the the water and push buttons and see what happens.
      If it gets messed up to bad, remember 'reset defaults'.. LOL   I did that a lot when I was new. And I do mean A LOT!
      Good luck and have fun.
               Mike
« Reply #4 on: May 17, 2012, 12:34:31 PM »
the 3rd image looks more like a speed issue. 18 mph is a bit fast for SI..
« Reply #5 on: May 17, 2012, 01:25:41 PM »
So you guys think all that garbage is a sensitivity issue?  I know it wasn't cranked all the way or anything.  Hmm.  Thanks for the replies.
« Reply #6 on: May 17, 2012, 01:39:04 PM »
I don't know if you have your switchfire set to max or clear.
Max will show everything in the water (plankton, thermoclines).
Clear will show you mainly fish.
The picture with 18mph could even be some interference from
your main motor.
Some of the units are pretty powerful.
My unit only needs a 2-d sensitivity set to 1.
Offline lcookie
  • Unit(s): 998SI/1198SI/788DI/587DI
  • Software: 6.68/6.64/6.64/6.09
  • Accessories: Ethernet, GRHA, ASGPSHS,WeatherSense
« Reply #7 on: May 18, 2012, 08:09:37 PM »
The junk looks like it could be biological or even a thermocline but not sure any lakes are set up for that yet.  Does it go away or get lower as the day goes on?  Check your switchfire setting and sensitivity as previously mentioned.
Last post April 02, 2011, 05:13:11 PM
Last post October 22, 2012, 08:56:37 AM
by BazzaD
Last post January 04, 2013, 04:48:49 PM
by trashboat
Last post February 01, 2013, 09:21:21 AM
Last post February 20, 2013, 06:36:05 PM
Last post March 21, 2013, 01:44:46 PM
Last post August 26, 2013, 07:35:00 AM
by Dirty Birch
