Author Topic: Rejoining AS GR50 cable?  (Read 7963 times)
Offline baza32000
  • Unit(s): 788ci
« on: May 14, 2012, 12:36:11 AM »
Hi Guys,
Was rushing to finish installation of a dual battery system, along with cutting the cable tie holding the bundled AS GR50 cable, I cut the whole cable in 2!
I thought no probs, it has 3 internal wires, a red, green and white. So I soldered the 3 wires back together, but the 788ci shows the gps as disconnected.
After reading a few posts here, it seems the shielding/bare wire might be the earth. I got 12v between the red and green, so thought the green was the power earth and the white was the signal wire.
Can anyone confirm I need to rejoin the shielding wire as well? Any tips, some aluminum foil maybe? Any help would be greatly appreciated.  Thanks, Glen.
Re: Rejoining AS GR50 cable?
« Reply #1 on: May 14, 2012, 11:27:16 AM »
There should have been a bare wire in there as well.  This is the ground for the GPS Receiver.  You should also rejoin the foil shielding as well.  The best way that I have found to do this is by stripping back the internal wires so that you have enough foil shielding to overlap the connection.
Offline baza32000
  • Unit(s): 788ci
« Reply #2 on: May 14, 2012, 08:01:00 PM »
Thanks Greg.
Last post September 07, 2009, 05:13:17 AM
by pebe
AS GR50 - SOLD
Started by bobcoy Classfied Ads
Last post October 26, 2009, 09:24:18 PM
by bobcoy
Last post January 04, 2011, 09:18:14 PM
by netman
Last post October 01, 2012, 12:48:21 PM
by diver651
Last post July 13, 2013, 06:51:56 AM
Last post May 12, 2014, 11:35:18 AM
Last post July 13, 2014, 09:53:52 AM
by hoffa09
Last post April 18, 2022, 08:42:08 AM
by FuzzyGrub
