Author Topic: Can the GPS AS GR50 be used stand alone  (Read 11418 times)
Offline gordp
  • Unit(s): GPS As-gr50
« on: September 26, 2011, 10:09:31 AM »
Hi there I am new so forgive me if I am posting this question in the wrong place.
I have an AS-GR50 and my 786ci head unit was borrowed one late night by someone who must have needed one very badly.  Night fishing I suppose...
My question is very simply, can I cut the connecter off the AS-GR50, run 12v to it and run the NMEA signals to my old Raymarine RC620 Plotter, or my Laptop running nobletec?
Thaks,
Re: Can the GPS AS GR50 be used stand alone
« Reply #1 on: September 26, 2011, 01:23:59 PM »
Although Humminbird would not officially recommend doing so; in theory this could be done.  I have not had anyone who has asked about doing this before communicate back to me whether this sort of this was successful or not.
Offline gordp
« Reply #2 on: September 26, 2011, 02:49:30 PM »
Good to hear.   Now I have cut the wire and there are only three wires.  A red, Green, White and a bare wire.
If Red is +12v
Bare is Ground
Are white and Green the + & - Nmea ?
So a cable would look like :
Red to +12v
Bare to Ground
Green to pin 5 of the DB9
White to pin 2 of the DB9
Or have I missed something?
Thanks,
« Reply #3 on: September 27, 2011, 11:17:17 AM »
I think that your connections would be:
Red wire to +12 volts
Bare wire to Ground
Green wire (NMEA Output of the GPS Receiver) to pin 3 of the DB9 connector
White wire (NMEA Input to the GPS Receiver) to pin 2 of the DB9 connector
From what I found online:
Pin 2 is In (Receive Data)
Pin 3 is Out (Transmit Data)
Pin 5 is Ground
Offline diver651
  • Unit(s): 1197, 1198
  • Software: 6.47
  • Accessories: Interlink, Aux Speed/Temp,
« Reply #4 on: October 01, 2012, 12:48:21 PM »
I have been successfully using a 16 channel GPS puck, a 50 channel, and one of the AS GRHA as GPS receivers for computer based mapping for years. I cut the NMEA-Comm end from the wye cable supplied with the pucks to fabricate Humminbird to serial DB9 adapters/connectors with a coaxial 12vdc power connection. See picture (if it makes it).
Mike
Last post May 01, 2009, 07:32:46 PM
Last post May 27, 2010, 01:44:05 PM
by wcahoe
Last post May 14, 2012, 08:01:00 PM
by baza32000
Last post May 12, 2014, 11:35:18 AM
Last post July 13, 2014, 09:53:52 AM
by hoffa09
Last post December 08, 2014, 09:46:02 PM
Last post June 25, 2018, 11:24:59 PM
by Nemrod
Last post April 18, 2022, 08:42:08 AM
by FuzzyGrub
