Author Topic: 998 & Terrova Issue  (Read 13870 times)
Offline Chet2142
  • Unit(s): 1198csi, 998csi
  • Software: 6.180
  • Accessories: GPS
998 & Terrova Issue
« on: May 10, 2012, 10:50:01 PM »
I just got my 998 back from Humminbird as I sent them in to be fixed and this one had a bad circuit board or parts on it that they had to replace. Got it back today, hooked up to the bow, and nothing.. no "Ticking" This is the same issue I was having before I sent it in. i thought this would do the trick but nope. Any ideas?
Offline NickO
  • Unit(s): 898c SI, 998CI HD SI
  • Software: 6.740, 6.740
  • Accessories: Ethernet
Re: 998 & Terrova Issue
« Reply #1 on: May 10, 2012, 11:29:49 PM »
Chet,
My 898 will sometimes start ticking at power up. But as soon as it doesn't get a return signal the ticking stops. Other times there is no ticking on power up. unit has performed flawlessly for over a year.
Do a water test that's where it's supposed to work, not in the garage  ;)
« Last Edit: May 10, 2012, 11:31:01 PM by nicko »
Gee that broke easy.
Offline Chet2142
  • Software: 6.180
  • Accessories: GPS
« Reply #2 on: May 10, 2012, 11:46:09 PM »
Ya, I know what you mean. But It worked when I bought the boat brand new last year for a while. and then it stopped. I sent in the units and also took my minn kota in and the minn kota guy said everything was within spec. So could it be the adapter wire?
Offline NickO
« Reply #3 on: May 11, 2012, 10:20:40 AM »
Chet,
Can you explain "adapter wire"?
Each unit should be wired directly to the cranking battery with an inline spade fuse. An awful lot of problems I read about on the boards, come from not being wired directly to the battery that's the first place I'd look.
Is your 1198 back yet? Can you swap unit heads just to see if that makes any difference?
I have heard of some putting their transducer in a bucket of water to test this ticking.
« Reply #4 on: May 11, 2012, 10:29:38 AM »
You should on-water test it before doing anything else.
It could be the adapter wire that is causing the proble, but I would wait for the on-water test before purchasing a new one.  If it does not work than try testing it on the 1198's transducer as Nicko suggested.
Nicko: there is an adapter wire that is needed to go from the Minn Kota connector type to the Humminbird connector type.
Offline Chet2142
  • Software: 6.180
  • Accessories: GPS
« Reply #5 on: May 11, 2012, 10:30:01 AM »
I mean the wire that connects HB to Minn Kota..
Both fish finders came back together and they told me nothing was wrong with my 1198. So thats a whole other topic later. :-) Not sure why all the problems when I bought this boat directly from the manufacturer (Skeeter in Kilgore, TX) last spring. I can say im not too happy, but I have to get them figured out as we leave for the Cabelas NTC on the 23rd!!
Offline Chet2142
  • Software: 6.180
  • Accessories: GPS
« Reply #6 on: May 11, 2012, 10:31:10 AM »
Greg, whats the correct cable I'd need for the 998 to the Minn Kota?
« Reply #7 on: May 11, 2012, 10:39:36 AM »
It would be the MKR-US2-8 but all you will get from the US2 transducer is the 200/83kHz 2D sonar and water temperature.
Offline Chet2142
  • Software: 6.180
  • Accessories: GPS
« Reply #8 on: May 11, 2012, 11:56:44 AM »
Thats all im looking for... But the Minn Kota guy I took the motor too tried to tell me that the 998 and 1198 are not compatible with the US2 on the motor..??
Offline rdstair
  • Unit(s): 1198C SI, 998C SI
« Reply #9 on: May 12, 2012, 04:09:00 PM »
Those are the two units I have. I was told that the US2 is only for 2D not SI or DI.
« Reply #10 on: May 14, 2012, 10:34:22 AM »
The US2 is not fully compatible (will allow all sonar capabilities) with the 998c Si and 1198c Si units but it is compatible with the 2D (200/83kHz) sonar.  Basically the US2 is the DualBeam transducer that we sell for use as a 2D sonar (only) transducer for these same units.
Offline rdstair
« Reply #11 on: May 15, 2012, 07:29:56 AM »
Can Hummibird make these into a SI and DI unit? It should not be that hard.What is the difference between a tranducer and an  US2 unit?
« Reply #12 on: May 15, 2012, 07:17:39 PM »
It wouldn't be up to Humminbird to do this, it would have to be Minn Kota.  Since Johnson Outdoors owns both companies, there might be a path for them to influence this.
That would be a good option to have....SI transducer built into the trolling motor with all necessary noise shielding.
Offline Roddy
  • Scan,scan and rescan
« Reply #13 on: May 15, 2012, 11:16:50 PM »
I copped out and installed a 180 HDSI on my Minn Kota salt water 80/60 I-Pilot works nice with no interference.
Roddy
Scan,Scan and Rescan Roddy
Last post March 16, 2010, 10:08:29 AM
Last post February 14, 2011, 09:52:42 PM
by weedsnager
Last post February 07, 2012, 03:48:48 PM
by nicknight
Last post February 29, 2012, 12:18:14 AM
by bft
Last post April 30, 2012, 02:11:49 PM
Last post December 20, 2012, 11:35:03 AM
by pebe
Last post January 19, 2013, 11:53:11 PM
by reddog
Last post February 25, 2013, 05:08:02 PM
by Kenneth Wright
