Author Topic: can't view the playback speed and play/back buttons  (Read 10831 times)
Offline prabbit7
  • Unit(s): 998
« on: May 08, 2012, 11:31:40 PM »
Hello,
I have my pc tower hooked up to a 32 in flat screen tv. Due to graphics card and I had to set the computer at lowest resulution setting to use the pc with the tv. 600X800 I believe. By doing that the place box seems to be set behing the top left and right image viewer screens. As a result, I can't see the play speed or check boxes for play and back. I imagine this control box could be fixed to stay put with what ever resulution you choose on your pc. It would be great if this could be fixed. If not, I need to upgrade my graphics card on my pc. I'll get to that, but probably later than sooner. Any thoughts to this regard?
Re: can't view the playback speed and play/back buttons
« Reply #1 on: May 09, 2012, 07:37:19 AM »
It's hard to understand what you are doing based on your description.
I assume you have Humviewer on your PC and you are trying to use your
big screen TV to view it with.
You probably need some type of converter between your pc graphics output
to your big screen TV input.  You probably have Video In(yellow) on the big screen.
I'm not sure, but you may even have RGB inputs on your TV which may be
better than Video.  Depending on how new your TV is, you could have something
even better.
I would take your owners manual for both your computer, big screen TV, and maybe
even the computer graphics card (if available) to radio shack.
Tell them you want the very best resolution you can get from the pc to the
big screen, and let them tell you what you need.
They may recommend you changing your computer graphics card.
Good Luck.
« Last Edit: May 09, 2012, 07:40:54 AM by ITGEEK »
Last post November 21, 2011, 04:41:58 PM
Last post July 09, 2013, 01:44:27 PM
Last post April 12, 2014, 11:39:41 AM
by mlhare
Last post November 23, 2014, 09:32:55 AM
by FJJJGSTRIPER
Last post January 23, 2015, 09:07:25 AM
by cache22
Last post August 05, 2015, 08:55:35 PM
Last post February 06, 2019, 09:58:37 AM
by Colorado #5
Last post December 10, 2019, 06:44:33 PM
by freezerfiller
