Author Topic: 917C Question  (Read 6604 times)
Offline BassinBill
  • Unit(s): 997si
917C Question
« on: April 18, 2012, 08:54:16 AM »
I have a 917c mounted in the bow of my Ranger bassboat.  The transducer is enclosed in the bottom of the MK 101 trolling motor.  About a month ago I turned on the unit and a verticle black line about 3/4" thick appeared on the screen.  About a week later a second verticle black line just to the left of the first appeared and the next week a thrid black line appeared just to the left of the second.  I now have three verticle black lines, each about 3/4" thick.  I ran a diagonostics check and everything came-up OK.
Any ideas?
Thanks,
BassinBill
Chapin, SC
Re: 917C Question
« Reply #1 on: April 18, 2012, 09:58:06 AM »
Does the unit display correctly when run in the Simulator mode (will have to plug in only the power cable for this)?
Are you able to display any menus or is the unit just not showing the bottom reading?
Do you have a second Humminbird unit or know of someone who has one that would allow you to connect up the power and transducer to test your 917c unit on it?  Most any model of Humminbird unit will work for this.
Offline BassinBill
  • Unit(s): 997si
Re: 917C Question
« Reply #2 on: April 18, 2012, 01:16:58 PM »
I will give your suggestions a try and see what happens.  Thanks for the assistance.
Last post January 15, 2010, 04:48:50 AM
Last post October 13, 2010, 02:46:28 AM
Last post February 06, 2011, 02:03:29 AM
Last post March 11, 2011, 09:59:09 AM
Last post March 31, 2011, 02:56:22 PM
by jjbch
Last post January 31, 2012, 04:44:43 PM
by HookonFishN
Last post March 26, 2012, 01:00:04 PM
Last post August 22, 2013, 01:43:10 PM
