Author Topic: 898 question?  (Read 9880 times)
Offline basszilla
  • Unit(s): 898c SI & 587ci & 998c HD SI
  • Software: Current
898 question?
« on: March 01, 2012, 03:46:24 PM »
Does the 898 come with two different transducers?  One for SI and the other for 2D sonar?
Re: 898 question?
« Reply #1 on: March 01, 2012, 03:57:55 PM »
Nope the single transducer has the elements combined...
Re: 898 question?
« Reply #2 on: March 01, 2012, 04:05:18 PM »
No.  The standard XHS-9-HDSi-180-T transducer that comes with the 898 units have both the 2D and Si sonar capability built into it.
Many by a second inside-the-hull 2D transducer (XP-9-20) and an AS-Si-DB-Y cable for the best highs-peed depth readings on a fiberglass hulled boat.  This also allows them to mount the HDSi transducer where it is more protected and can possibly work better for the Si sonar.
Offline basszilla
  • Software: Current
Re: 898 question?
« Reply #3 on: March 02, 2012, 10:16:01 AM »
Great Infomation guys.  Can't wait to get my unit.  With the help of this forum I have a good idea what I need to do to get this unit installed.
Offline basszilla
  • Software: Current
Re: 898 question?
« Reply #4 on: March 25, 2012, 03:24:54 PM »
My unit is running the SI ducer when I am scanning, but when I run full speed I want to switch to my shoot thru hull 2d sonar. My under standing is the SI ducer also produces 2d sonar. How do I know I am selecting the shoot thru hull ducer and not the SI ducer?  I am using the Y connector for the 2 ducers.
Re: 898 question?
« Reply #5 on: March 26, 2012, 01:00:04 PM »
With the AS-Si-DB-Y cable you do not choose which transducer the 2D sonar comes from as only the inside-the-hull transducer is electrically connected to your 898 unit.
If you want to be able to select which transducer you are using for the 2D sonar you need to buy and install the TS3 Transducer Switch and plug both transducers into it.  Than you will control which transducer you are using for the 2D sonar by toggling the switch.
Last post January 15, 2010, 04:48:50 AM
Last post August 23, 2010, 02:40:53 PM
by DoubleGobble00
Last post October 13, 2010, 02:46:28 AM
Last post February 06, 2011, 02:03:29 AM
Last post March 11, 2011, 09:59:09 AM
Last post March 31, 2011, 02:56:22 PM
by jjbch
Last post January 31, 2012, 04:44:43 PM
by HookonFishN
Last post April 18, 2012, 01:16:58 PM
by BassinBill
