Author Topic: 898si side imaging veiw  (Read 6746 times)
Offline hardware40
  • Unit(s): 898si
« on: April 16, 2012, 03:08:31 PM »
is there any way when your on side imaging veiw to make it full screen. i have depth in bottom left but it is blanked out the rest on the left.all other veiws are fine. just have this white bar on left .
Re: 898si side imaging veiw
« Reply #1 on: April 16, 2012, 04:14:47 PM »
Select advanced mode...
then go to set up menu and select readouts
then pick the one's you want...
Any readout that is showing off will not display on the screen..
use the cursor in the select readout to select or turn off..
chuck
« Last Edit: April 16, 2012, 04:51:40 PM by sonar2000 »
« Reply #2 on: April 17, 2012, 12:32:54 PM »
Make sure that you are running the current software version.
Than go to the Sonar menus and look for the SI Readouts menu and set it to “Off”.  There is another post on this complete with a link to a video that shows this:
http://forums.sideimagingsoft.com/index.php?topic=3927.msg23611;topicseen#new
Offline hardware40
  • Unit(s): 898si
« Reply #3 on: April 17, 2012, 06:07:04 PM »
yes i figured it out yes you need the current soft ware work good now
« Reply #4 on: April 17, 2012, 07:20:12 PM »
HardW...thanks for the feed back. It is always nice to know the "fix".
Last post January 02, 2010, 10:38:32 AM
by IRC Kevin
Last post June 24, 2010, 08:42:29 AM
by mtbasser
Last post May 01, 2013, 11:43:44 AM
by mikes951
Last post October 28, 2011, 05:43:43 PM
by kkingon
Last post November 29, 2012, 11:42:40 AM
