Author Topic: Help With Side Imaging  (Read 32334 times)
Offline mcfred2004
  • Unit(s): 858, 898
  • Software: 5.4
« on: March 20, 2011, 12:36:47 AM »
Just had a 898C SI unit put on my boat.  When viewing both the Left and Right side, the right side is black?  Any ideas?
Offline stillbear
  • Stillbear
  • Software: 5.840 5.700- 4.0
Re: Help With Side Imaging
« Reply #1 on: March 20, 2011, 02:10:19 AM »
Where do you have the transducer mounted. Can you post a side view image and
a rear image of the installation. Gary
Offline mcfred2004
  • Unit(s): 858, 898
  • Software: 5.4
« Reply #2 on: March 20, 2011, 03:33:35 PM »
Yesterday was the first day out and I did not get any pictures of the Right side being black.  Here is the tranducer mounted.ila_rendered
« Reply #3 on: March 20, 2011, 04:42:51 PM »
It looks a little high....maybe a bit upward tilt......Is this on the left (port) side of the transom....If so the motor may be blocking the right beam....
Maybe take the picture from a bit farther back to show the whole back side...
« Last Edit: March 20, 2011, 04:43:52 PM by sonar2000 »
« Reply #4 on: March 20, 2011, 06:41:40 PM »
With the transdcuer mounted on the step, it is going to cause issues with turbulence coming off the bottom of the hull.
Post some snapshots of what you are (or arent) seeing on the screen.  Also a shot of the transducer mount from the side so we can see the depth of the step on the hull.
Just from this though, I would definitely say the transducer needs to be mounted lower down on the bottom step.
Offline mcfred2004
  • Unit(s): 858, 898
  • Software: 5.4
« Reply #5 on: March 20, 2011, 06:58:19 PM »
The transducer is on a Ranger Reata 186.  It is mounted on the starboard side of the boat.  The unit was installed by a Ranger/Humminbird dealer.  Here is a couple of more pictures.ila_renderedila_rendered
Offline stillbear
  • Stillbear
« Reply #6 on: March 20, 2011, 11:43:43 PM »
I would start with moving the toe or outer most end of transducer up at least 3 clicks
 Make sure motor is lifted up while using SI .  Gary
« Reply #7 on: March 21, 2011, 07:32:32 PM »
If mounted on the starboard side I dont see why you should have a blank right si..If any thing it should be the left...
Check your si and make sure you are seeing  the left....there was a problem posted a bit ago about the possibility of the transducer being backwards in the display.  Right was left.  I will see if I can dig up that post and see if any fix was given...
Let us know if you can determine the right vs left si image.
chuck.
Offline mcfred2004
  • Unit(s): 858, 898
  • Software: 5.4
« Reply #8 on: March 22, 2011, 03:25:16 PM »
I have decided to take the boat back to the dealer.  I will post what the resolution is.
Thanks for your help.
« Reply #9 on: March 22, 2011, 05:30:15 PM »
Thanks and do keep us informed.
Depending on the fix it may help others....
Offline mikes951
  • Accessories: 598ci
« Reply #10 on: May 01, 2013, 11:43:44 AM »
Thanks for pic's i have a 190 reata just bought a 598ci just trying to figure out where to mount it do it my self or take it to the ranger dealer all the cable is run just need to be mounted what would the dealer charge around just mounted?
by Wylezalek
Last post September 09, 2013, 01:28:56 PM
by prowler650
Last post October 26, 2015, 09:34:42 PM
Last post July 19, 2017, 12:27:05 AM
Last post May 30, 2018, 08:11:04 AM
