Author Topic: San Disk or other SDHC card  (Read 12284 times)
Offline rdstair
  • Unit(s): 1198C SI, 998C SI
« on: April 12, 2012, 07:49:05 PM »
Is it best to use a San Disk SDHC card or can you use other ones like a PNY class 10  with 20 MB/S transfer rate. It will be in a 1198c SI unit. On the forums I hear about San Disk all the time but not other brands.
Re: San Disk or other SDHC card
« Reply #1 on: April 13, 2012, 09:22:46 AM »
Not to disparage any company but I prefer the sandisk. I cant qualify that except to say that in all our applications the sandisk has performed.
« Last Edit: April 13, 2012, 11:25:48 AM by sonar2000 »
Offline walleyhunter
  • Unit(s): 1198c-si
  • Software: 6.180
« Reply #2 on: April 13, 2012, 11:16:15 AM »
agree with sonar on the sandisk, we use a lot here at my company to interface with  microcontroller's to store data and they have performed well.
Offline rdstair
« Reply #3 on: April 14, 2012, 03:04:17 PM »
Is there a particular version of the san disk that is better than the others. Even other san disk versions.
  • Unit(s): 1198c-si
  • Software: 6.180
« Reply #4 on: April 14, 2012, 04:05:52 PM »
business class versions are the best but unnecessary for what you are doing. Nonetheless just buy one at your local store and you will be fine.
« Reply #5 on: April 17, 2012, 01:56:52 PM »
The whole deal with the SanDisk brand memory cards is that they follow the guidelines set up by the SD Association (they are a founding member).  So if you are designing a product to use SD cards what criteria would you go by?  Hopefully those set by an international organization such as the SD Association…
Offline rdstair
« Reply #6 on: April 18, 2012, 12:31:57 PM »
I bought a PNY card that accepsts imiagmes from the graph. I have not tried video on it yet. Should this card be okay?
« Reply #7 on: April 18, 2012, 01:12:31 PM »
It may be.  I would expect that if you can write and read image files (save and view Screen Snapshots) to/from the memory card that it will work for sonar recordings as well.
« Reply #8 on: April 18, 2012, 10:09:12 PM »
Yes, the PNY works as well as the sandisk. the only difference may be when you get to the new typing of the cards and large card sizes.
« Reply #9 on: April 19, 2012, 10:21:47 AM »
We have had reports of the PNY SD and SDHC memory cards both working and not working.  I don’t know if this is tied to a specific memory card type, size, speed or even production date.  So it is hard to say that all will or will not work.  Since you have the memory card you can try it without causing any harm.
« Reply #10 on: April 19, 2012, 10:38:43 AM »
On the other hand these are not expensive so shop the sales and see who works and who doesnt.
both short term and long term...
What works for one application may not work for another but in the end each will have a use, so your money is not wasted..
SD cards are for many applications..
Last post June 03, 2009, 10:37:51 AM
by HawgHunter
Last post January 20, 2013, 07:28:46 PM
by freezerfiller
Last post September 29, 2010, 01:03:57 AM
by Enufzed
Last post February 16, 2012, 06:12:38 PM
by depark1
Last post March 12, 2012, 04:38:16 AM
by stillbear
Last post May 07, 2012, 03:20:09 PM
Last post December 31, 2012, 10:47:56 AM
Last post September 05, 2014, 09:13:56 PM
by mike1957
