Author Topic: Hb 898 sd card Tip  (Read 13409 times)
Offline Kenosha
  • Unit(s): HB 898
Hb 898 sd card Tip
« on: August 16, 2010, 07:04:49 PM »
I had a problem removing the SD card because my fingers don't fit.
I drilled a .030" hole 1/8" down from the top of the SD card and tied a short piece of fishing line in the hole works great.
Offline stillbear
  • Stillbear
  • Software: 5.840 5.700- 4.0
Re: Hb 898 sd card Tip
« Reply #1 on: August 17, 2010, 06:50:49 AM »
Good idea i have the same problems fat fingers.   Gary :)
« Reply #2 on: August 17, 2010, 02:51:28 PM »
Just remember, the SD card slot has a push in - pop out inser/eject mechanism.  Do not yank the card out with the pull string while the eject mechanism is engaged.
Offline Enufzed
  • Enufzed
  • Oh happy days !!
  • Unit(s): 898cx SI
  • Software: V 6.180
« Reply #3 on: September 23, 2010, 06:17:14 AM »
IS THERE A SPECIAL TYPE OF SD CARD REQUIRED
THANKS
Wayne P.
  • Guest
« Reply #4 on: September 23, 2010, 06:41:11 AM »
No, but a class 6 or 10 will lessen the time it takes to do snapshots.
You can use up to a 32 gb card. I use a 2 gb or 4 gb .
Offline Enufzed
  • Enufzed
  • Oh happy days !!
  • Unit(s): 898cx SI
  • Software: V 6.180
« Reply #5 on: September 23, 2010, 07:05:07 AM »
THANKS . Only had it a couple of days and it came with very little instructions
Geoff .     Australia
« Reply #6 on: September 23, 2010, 08:01:21 AM »
Although not required we do recommend using the SanDisk brand SD and SDHC memory cards.  They make the Ultra II and Extreme III (fast and faster) models of SDHC memory cards that work well in our products.
« Reply #7 on: September 28, 2010, 06:21:03 PM »
I keep several 2GB Sandisk Extreme III cards in the boat ....
1 with the latest software version
1 with the previous software version
1 with saved snapshots and recordings
1 with all my backed up waypoints
1 for the day at hand info
SD cards are cheap...
Offline Enufzed
  • Enufzed
  • Oh happy days !!
  • Unit(s): 898cx SI
  • Software: V 6.180
« Reply #8 on: September 29, 2010, 01:03:57 AM »
Thanks for the info. A good idea to keep them all separate
Regards
Geoff
Last post April 29, 2010, 09:21:23 AM
by kskloss
Last post April 30, 2010, 01:46:21 PM
Last post May 13, 2010, 02:24:47 PM
Last post June 19, 2010, 11:51:58 PM
Last post June 22, 2010, 12:17:06 PM
by RzorbackAngler
Last post August 11, 2010, 02:42:47 PM
by Wayne P.
Last post August 12, 2010, 11:50:13 AM
by IRC Kevin
by slabbandit
