Author Topic: Cannonlink model numbers  (Read 22551 times)
Offline bbordeau
  • Unit(s): 797c2
« on: April 11, 2012, 08:44:16 PM »
I see two separate model numbers online by various vendors - what is the difference between the two units?
Model Numbers are - 406930-1 and 1903040.
Brian
Re: Cannonlink model numbers
« Reply #1 on: April 12, 2012, 09:18:13 AM »
the 406930-1 is the HB model number.
I found the second number 1903040 as a cannonlink but was from the HB parent company Johnson Outdoors..
which store did you buy it from?
chuck
« Last Edit: April 12, 2012, 12:16:41 PM by sonar2000 »
« Reply #2 on: April 12, 2012, 12:18:27 PM »
I have also found 1903040 on HB..
So disregard my comments..
I dont know what these numbers mean.. :P
Hopefully some one does and will let you know..
« Reply #3 on: April 12, 2012, 12:56:53 PM »
Sounds like a question for the folks from Cannon… but i will try and help anyways.
Let’s see; the Cannon web site lists the CannonLink as part number 1903040
The Humminbird web site also now lists it with the same part number.  The 406930-1 part number was the part number that Humminbird used when we built and marketed the CannonLink.  That is now being done by Cannon, so I don’t know if there were any changes to it or not but either part number should work.
« Reply #4 on: April 12, 2012, 01:09:44 PM »
You shouldn't have sold it but rather kept it  in Johnson outdoors.., ;D... :o... ::)
OOOPPPSSS I think that Johnson Outdoors still owns cannonlink.  Not HB.  You guys(hb)  still should have kept it..>
« Last Edit: April 12, 2012, 01:17:26 PM by sonar2000 »
« Reply #5 on: April 12, 2012, 05:21:17 PM »
Cannon downriggers is still owned by Johnson Outdoors, Inc.  This is the same parent company that owns use and many other companies.
Offline bbordeau
  • Unit(s): 797c2
« Reply #6 on: April 15, 2012, 02:12:50 PM »
Thanks guys, I haven't bought it yet, I was just looking online and doing some background research on it and came across the two numbers...
Last post April 23, 2009, 08:48:53 AM
by Keith Councell
Last post June 26, 2010, 12:36:14 PM
Last post May 13, 2011, 11:34:42 AM
Last post July 14, 2012, 11:04:09 PM
by stevemc
Last post December 19, 2012, 04:21:04 PM
Last post December 25, 2012, 02:21:34 PM
by cestes
Last post June 05, 2014, 08:46:19 AM
Last post March 02, 2015, 04:06:53 PM
