Author Topic: gps numbers  (Read 9453 times)
Offline marcuswon
  • Unit(s): 798ci hd si
  • Software: ?
  • Accessories: none
gps numbers
« on: May 12, 2011, 12:19:56 PM »
how can i add gps number to a sd card so when it is put in the unit it will show them on the unit?
Re: gps numbers
« Reply #1 on: May 12, 2011, 12:30:45 PM »
Are you aksing to add a GPS coordinate? Like lon/lat...
Offline marcuswon
  • Software: ?
  • Accessories: none
Re: gps numbers
« Reply #2 on: May 12, 2011, 12:38:06 PM »
yes..like go the  county reef and wreck site and get the number and put them in so when i go out they are in there so i can find them.i know i can go find the in the water and the mark them but would like to have them preloaded if possible.
Re: gps numbers
« Reply #3 on: May 12, 2011, 12:48:13 PM »
You should be able to go to the nav menu and select a create waypoint. this will let you put in the gps coord...
I think you have to be in advanced mode to do this..
Re: gps numbers
« Reply #4 on: May 12, 2011, 04:38:05 PM »
You can also do this through the HumminbirdPC program as well.  If those waypoints are in a file format you could possibly import them en masse.  Just be sure that the Waypoint Format you are using is the same as the unit or HumminbirdPC is set to and that they are using the same Map Datum as well (HumminbirdPC only uses the WGS84 Map Datum).
Offline marcuswon
  • Software: ?
  • Accessories: none
Re: gps numbers
« Reply #5 on: May 12, 2011, 06:12:58 PM »
here is what i want to put on a sd card and install these way points before i ever get into the water..my unit is brand new and just  finished installing it yesterday..never been i the water....
http://www.pensacolafishingforum.com/f25/recent-reef-deployment-s-81504/
first time to link something on here maybe it will work..i know that i can go and find these reefs and wrecks and mark them as a way point but i would like to have them stored before i go .it would make it easy to find if the where already marked....
i think i got the link fixed..
look at the bottom at the Artificial_reefMASTER_list_21Jan2011.pdf  and it has more of the way point i want to add...
and the
« Last Edit: May 13, 2011, 11:12:00 AM by marcuswon »
Re: gps numbers
« Reply #6 on: May 13, 2011, 11:34:42 AM »
marcuswon,
I am assuming that these are referenced to the WHS84 map datum.  Send me a direct e-mail to me with the same link to that page and I will see what I can do about converting these for you and than I will e-mail them back.  I cannot do it today as the files I need for this are on my work PC and I am at home now (food allergy took me out last night…).
Chuck/Robert,
Maybe you could start a separate section in the Downloads section for *.gpx files of public waypoints?  I’ve converted several of these that I could place out there for others to use.  For a fee I might upload someone’s personal waypoints as well!   :o  >:D
No, I wouldn’t do that guys…  ;D  Your waypoints are yours and yours alone.  Waypoints from a publically accessible web site are fair game though.
Last post April 15, 2012, 02:12:50 PM
by bbordeau
Last post July 14, 2012, 11:04:09 PM
by stevemc
Last post December 19, 2012, 04:21:04 PM
Last post December 25, 2012, 02:21:34 PM
by cestes
Last post February 12, 2013, 04:05:21 PM
by bobxxx
Last post March 31, 2013, 09:22:50 PM
by Rough House
Last post June 05, 2014, 08:46:19 AM
Last post March 02, 2015, 04:06:53 PM
