Author Topic: 5.7 update for 898  (Read 5471 times)
Offline RonnieF
  • Unit(s): 998 & 898
5.7 update for 898
« on: April 11, 2012, 02:22:58 PM »
I have a brand new 898. The first time powering it up, I updated to the 6.180 (not sure of the last 2 numbers). I then started adjusting the settings and noticed the the only colors i can change to are blue and gray. Amber1, Amber2, Brown, Green/Red are all close to black colored. It was reccommended that i could back up to the 5.7 update to see if the color selection returns.
Would anyone have a link to this update or any other reccommendations?
Thanks,
Ronnie
Re: 5.7 update for 898
« Reply #1 on: April 11, 2012, 02:32:39 PM »
Ronnie, you can go to the downloads section on this forum and go to back level code..
Look at the top of the main page. select downloads, select your model, then download you selection.
Remember to only have one down load on the sd Card..
Make sure to restore factory defaults prior to chaning code and again after the code has loaded..
I would not put any waypoints on the card until the code has loaded successfully.
chuck
« Last Edit: April 11, 2012, 02:41:00 PM by sonar2000 »
Offline RonnieF
« Reply #2 on: April 11, 2012, 03:18:01 PM »
Thanks Chuck. The download was located and saved to a SD card. I'll see how it works.
Ronnie
Offline Gattlin
« Reply #3 on: April 11, 2012, 03:36:26 PM »
 Will the 5.7 update for the 898c si work for the 858c combo I noticed my 858 has 4.7 on it just curious because I don't see the 858 listed in the downloads section. Thanks in advance Sorry not trying to derail your thread.
« Last Edit: April 11, 2012, 04:06:28 PM by Gattlin »
Just one last cast.
Offline RonnieF
« Reply #4 on: April 11, 2012, 03:43:04 PM »
Didn't work. Still just see blue, black, and gray. I guess I have to get in touch with HB to see how to proceed.
Ronnie
« Reply #5 on: April 11, 2012, 04:27:54 PM »
Gattlin.  no the 898 will not work on the 858.
Let me see if I can get an update for the 858 and send it to you..
Update from moderator: 858 now has a section in the downloads.  You can down load from there.
Back to the thread for RonnieF:
Give HB customer support a call.
chuck
« Last Edit: April 12, 2012, 09:29:09 AM by sonar2000 »
Offline Gattlin
« Reply #6 on: April 11, 2012, 07:05:19 PM »
 Thank you and I'll post something like that in it's own thread next time  sorry Ron
Just one last cast.
Offline RonnieF
« Reply #7 on: April 11, 2012, 09:29:46 PM »
Not a problem at all Gattlin. Good luck.
Ronnie
« Reply #8 on: April 12, 2012, 09:30:59 AM »
Ron, we should have had the 858 in the downloads.
So no problem with your post...You made us get to work and put it there.
Thanks, Chuck
Last post February 09, 2011, 05:49:52 PM
by majflyboy
Last post April 14, 2011, 12:23:12 PM
Last post May 11, 2011, 11:12:15 AM
by jgollihar
New 5.7 update
Started by edwardpic « 1 2 » 898c SI
Last post August 07, 2011, 10:34:13 AM
Last post July 30, 2011, 03:48:36 PM
by SkeeterMatt
Last post March 08, 2012, 06:29:06 AM
by alnash
