Author Topic: HB PC Update 4.1  (Read 17761 times)
Offline stillbear
  • Stillbear
  • Software: 5.840 5.700- 4.0
HB PC Update 4.1
« on: July 21, 2011, 07:40:34 PM »
New HB PC Update is posted I just downloaded Bring on the New Waypoint Management Program
Gary
Offline pig75
  • Unit(s): 798, matrix17, lcr400
Re: HB PC Update 4.1
« Reply #1 on: July 21, 2011, 09:22:52 PM »
Just downloaded it but it wont read my GPX files
Offline calli1
  • Unit(s): 1198 S I & 787c2i
« Reply #2 on: July 21, 2011, 10:05:55 PM »
Just downloaded mine and now I can't even pull up my Humminbird P C.....huummm...HELP!!!!
« Reply #3 on: July 22, 2011, 11:50:46 AM »
Did you guys uninstall the previous version of HumminbirdPC before installing the 4.4.1 version?
Pig75,
Where was this *.gpx file from: your Humminbird unit (which model), one you made using only an older version of HumminbirdPC or one you made by importing data from another brand unit or program?
Offline pig75
« Reply #4 on: July 22, 2011, 05:31:27 PM »
Yes removed previous version.
It's a 798cxi
The unit file and a older humminbirdPC version all the same error message
« Last Edit: July 22, 2011, 10:49:27 PM by pig75 »
Offline NickO
  • Unit(s): 898c SI, 998CI HD SI
  • Software: 6.740, 6.740
  • Accessories: Ethernet
« Reply #5 on: July 22, 2011, 10:36:28 PM »
Same message here Greg. All my GPX files created on the same 898c and created with Humminbird PC 3.2.2.
 However I was able to create a new gpx readable file when I imported from yesterday's trip.
What's up
Gee that broke easy.
Offline bflipn
« Reply #6 on: July 23, 2011, 08:54:06 AM »
Same problem here with same error message  I cannot pull up any of my previous .gpx files
Offline stillbear
  • Stillbear
« Reply #7 on: July 23, 2011, 11:41:06 AM »
Hey Greg I never uninstalled the old HB PC my new update to 4.1 works
fine do you care to elaborate on that. Gary
Doc Stressor
  • Guest
« Reply #8 on: July 23, 2011, 03:02:39 PM »
I just installed 4.1 and everything works fine except for a bug that shows the names of all the waypoints twice in Google Earth. This only happens if I click on the .gpx file itself. If I click on waypoints (the next level down), the names are only displayed once.
The Groups feature is going to change the way that I live. THANK YOU! With over 300 Gulf of Mexico waypoints saved up over 30+ years, scrolling down the entire list was a pain.
For you guys having problems with the update, remember that it's an update not full program. If you uninstall the older program, 4.1 will not install. Also, you need to be running the latest version of Java (update 26) in order for 4.1 to operate properly.
Offline Enufzed
  • Enufzed
  • Oh happy days !!
  • Unit(s): 898cx SI
  • Software: V 6.180
« Reply #9 on: July 23, 2011, 05:59:49 PM »
My anti virus software ,"AVG" picked up a suspected virus in a CAD file 5mb in size whilst installing the update. The AVG put it in the virus vault and no more problems with the 4.1 version. it seems to be working fine now.  I did install it as an update and did not remove the old edition first.
Offline stillbear
  • Stillbear
« Reply #10 on: July 24, 2011, 07:52:34 AM »
Greg , Chuck or Robert the new HB PC 4.1 update downloads ok but the problem is it don't work
won't let you do anything with waypoints etc. Sorry Gary
« Last Edit: July 24, 2011, 09:56:08 AM by stillbear »
Doc Stressor
  • Guest
« Reply #11 on: July 25, 2011, 05:49:53 AM »
Everything worked smoothly in 4.1 until I tried to upload files to an SD card.
I get the error message:
Upload Data Error.
Null
Card was freshly formated.
Offline stillbear
  • Stillbear
« Reply #12 on: July 25, 2011, 10:04:28 AM »
How about HB control center would appreciate some kind of response about 4.1.1 HB PC update
Thanks Gary
« Reply #13 on: July 25, 2011, 06:33:10 PM »
Sorry guys but was busy the last two days at home and did not have time to look at this web site.  Could not stay on today... kept locking up and kicking me out.
The 4.1.1 HumminbirdPC is a full program so you should uninstall the previous version.
You need to make sure that you are running the latest version of Java as well as having your Windows updated.
For those who get the Upload Data Error - Null messag when you try and upload your waypoints to the SD memroy card: this is a bug in the program but you can get around this by having an *.hwr file on the SD memory card already.  Download the waypoints from your unit via the SD memory card as you normally would but do not erase or format the SD memory card.  Just select to "Replace" the file whenever you upload your waypoints back to the SD memory card.
Just be aware that while you can set different groups in the HumminbirdPC program; they will not be recognized by your unit until the Waypoint Management software is (finally) ready - which will be... [had you going there didn't I?] I don't know when.  ;D
Offline stillbear
  • Stillbear
« Reply #14 on: July 26, 2011, 10:29:28 AM »
Greg it will be soon. Thanks Gary
Doc Stressor
  • Guest
« Reply #15 on: July 27, 2011, 11:18:58 AM »
Quote
You seem to need more than just a *.hwr file on the SC card. Copying an existing .hwr to the card from the computer doesn't work. Neither does putting it into a Matrix folder and including a Profile file. It seems like you have to actually download navigation data from a unit in order for the update to replace the information.
I can't do this with my Matrix 97 since it doesn't have a data export function. I have to go to the marina to access the 997 on my bigger boat.  What a PITA!
Is the older version of Humminbird PC still available for downloading somewhere? I only see much older versions available on this site.
« Reply #16 on: July 27, 2011, 12:59:37 PM »
Doc,
What software version are you running in your Matrix 97 unit?  I don’t have one to check this with but there should be an Export Nav Data menu in it.  Make sure that you are running in the Advanced User Mode menu setting.
Yes it is a PITA but most users will be using the same SD card that they used to export their Nav data from their units with.  The file structure needed is there and in place so it works for them.
The older versions of HumminbirdPC are available on this web site (I don’t know of anywhere else).  Look in the Downloads section.
Doc Stressor
  • Guest
« Reply #17 on: July 28, 2011, 08:57:10 AM »
I needed to use the advanced setting in order to delete the waypoints. :P
Humminbird help pointed that out to me yesterday.
My upgrade to the latest software had restored the default settings and I forget to set them back.
I saved nav data to a couple of empty SD cards so I should be good to go with 4.1.
Offline SkeeterMatt
« Reply #18 on: July 30, 2011, 03:48:36 PM »
my hb defaulted to east instead of west in the create waypoint screen. everything works fine. i appologize for harsh words earlier. thanks for your help.
Last post January 12, 2010, 09:27:37 PM
by Macca
Last post January 14, 2010, 06:51:41 PM
Last post April 14, 2011, 12:23:12 PM
Last post May 05, 2014, 09:10:54 PM
Last post July 18, 2015, 03:43:29 PM
by 6speedy3
Last post January 31, 2018, 09:20:10 PM
