Author Topic: 798ci hd v 6.250  (Read 11348 times)
798ci hd v 6.250
« on: April 04, 2012, 06:25:28 PM »
New file added to the 798 ci HD folder.
The folder contains both the long name 9dc04..... and the 6.250.bin
Offline Ggw2000
  • Unit(s): 798ci hd si
Re: 798ci hd v 6.250
« Reply #1 on: April 05, 2012, 12:21:04 PM »
Chuck, do you know or is there a place to find out what this update does for the 798ciHD? Just got my 798 a couple weeks ago and it
has not to date even been hooked to a transducer. Since this is the case I have a question- the humminbird "update" video shows to have
the unit powered on and then insert the SD card with the new F/W on it and the unit will recognize the card and ask if you want to update.
In my situation, in turning on the unit would I go to "normal" startup before inserting card even tho there is not a transducer hooked to the unit? I'm quite sure you don't want to be in "simulator" mode. Little confused..
Thanks, Gerry
« Reply #2 on: April 05, 2012, 12:58:04 PM »
Not sure of what all is in the update. HB does not always tell what is fixed or changed.
I would venture a guess and say something to do with waypoints.  but just guessing.
It is suggested that after restoring defaults you turn off the unit. Insert the sd card containing only the update and turn on the unit.
Wait until the process is finished. Dont be in a hurry for this to finish quickly...
Turn off the unit, remove the card and power on. then set your customized settings. Remember that views will be default so every thing you set will have to be redone.
Offline wolfs4evr
« Reply #3 on: April 05, 2012, 01:10:20 PM »
List of new features (6.250)
http://www.humminbird.com/FAQ.aspx?ContentId=3501
This update takes less than a minute at most to install.  Suppppper fast install.
« Last Edit: April 05, 2012, 01:11:22 PM by wolfs4evr »
Offline Ggw2000
« Reply #4 on: April 05, 2012, 01:20:25 PM »
Thanks for the replies to both of you. Might try to update this weekend.
Gerry
« Reply #5 on: April 05, 2012, 01:27:47 PM »
Thanks for the help.  I had forgottten about the FAQ's section..
I guess Robert should make you the looker uper of information. ;D... ::)... :P
I downloaded from your site also.
The one I put in the downloads section is from HB.
Offline Ggw2000
« Reply #6 on: April 05, 2012, 03:56:16 PM »
Updated completed  ;) - thanks for the help!
Gerry
« Reply #7 on: April 05, 2012, 04:25:33 PM »
Good job.  Catch some nice fish and take some pictures.
chuck
Offline Ggw2000
« Reply #8 on: April 05, 2012, 04:36:45 PM »
Yea - 42 degrees F here today, windy and going down below freezing the next couple nights! Where's spring ? Going to be end of April
before new boat sees water i'm afraid  :'(.
Gerry
Last post July 11, 2012, 04:54:29 PM
by Speedtroller
Last post December 02, 2013, 12:08:31 AM
Last post March 17, 2014, 11:38:18 AM
798Ci HD
Started by Chad 798c SI
Last post March 27, 2014, 11:42:38 PM
by Rotus623
Last post March 31, 2014, 11:56:01 AM
Last post May 19, 2014, 04:36:40 PM
by bigredeyebass
Last post October 13, 2014, 10:28:22 PM
by xSilmarilSx
Last post March 03, 2017, 10:55:06 PM
