Author Topic: o no i downloaded 6.3, for 798ci i have a 798ci si. help.  (Read 11781 times)
Offline bigredeyebass
  • Unit(s): 798ci
« on: May 18, 2014, 09:55:23 AM »
does  it matter , both the same size 209MB  or should i remove it and replace with proper one.
« Last Edit: May 18, 2014, 10:03:11 AM by bigredeyebass »
Re: o no i downloaded 6.3, for 798ci i have a 798ci si. help.
« Reply #1 on: May 19, 2014, 01:04:56 AM »
Better wait for Greg on this one...
He'll check in Monday I'm sure...
« Reply #2 on: May 19, 2014, 12:45:40 PM »
Each model unit has its own set of software updates and they should not load the other model’s update.  Even different models like the 798c Si,  798ci Si and 798ci HD Si all have different software update files and they should not load the other unit’s update file.  Even if the update files are for the same revision number (Ex: both are 6.300) they are different files for different units.
The 798ci Si and 798ci HD Si are the only 798 models with “ci” in their model name (excluding the different international models here), so I would assume that these are in fact the same unit and same update file.
  • Unit(s): 798ci
« Reply #3 on: May 19, 2014, 04:12:33 PM »
Hi ok  thank you , so reinstall the one for my unit than,  and did I harm my unit  did I change its program.
« Reply #4 on: May 19, 2014, 04:15:51 PM »
No, you should not have caused it any harm.
  • Unit(s): 798ci
« Reply #5 on: May 19, 2014, 04:36:40 PM »
Thank you living  it alone.
Last post August 01, 2009, 10:10:40 AM
by jimbo
Last post March 15, 2012, 05:56:35 PM
Last post April 05, 2012, 04:36:45 PM
by Ggw2000
798ci HD SI
Started by hgv 798c SI
Last post May 09, 2012, 01:12:51 PM
by hgv
Last post July 11, 2012, 04:54:29 PM
by Speedtroller
Last post December 02, 2013, 12:08:31 AM
Last post March 17, 2014, 11:38:18 AM
798Ci HD
Started by Chad 798c SI
Last post March 27, 2014, 11:42:38 PM
by Rotus623
