Author Topic: Humminbird PC upload add/replace  (Read 24699 times)
Offline LBloch
  • Unit(s): 998c SI, 958c
  • Software: 6.18
« on: April 03, 2012, 11:32:29 PM »
I'm having problems with uploading files onto a sd card.  I keep my waypoints organized by the lake they are on in Humminbird PC.  When I want to put the waypoints for multiple lakes on one SD card the files are only replacing and not adding to the SD card.  For example, if I want to put the waypoints for Lake Sharpe and Lake Frances case on one SD card, I highlight the file for Sharpe and right click it and choose upload. I get the prompt to add or replace and I choose add. Then I highlight the Frances Case file and right click, choose upload and add but when I look at the files on the SD card only the Frances Case waypoints are there even though i chose "add".  It was working for me fine but I don't know what happened. Anyone else have this problem?  Am I overlooking something simple? I'm still kind of new to this stuff so its likely that it's operator error.  Thanks.
Re: Humminbird PC upload add/replace
« Reply #1 on: April 04, 2012, 10:22:10 AM »
What version of HumminbirdPC are you using?
As a work around you should be able to bring both files up in HumminbirdPC, create a third file and copy and paste the waypoints from the Lake Sharpe and Lake Frances files into it.
Offline LBloch
  • Software: 6.18
« Reply #2 on: April 04, 2012, 10:31:03 AM »
Version 4.2.  That's what I have been doing, creating a new file, it works just fine.  I was thinking maybe I would uninstall and install Humminbird PC again and see if it makes any difference. Thanks Greg.
« Reply #3 on: April 04, 2012, 10:39:06 AM »
Thanks ibloch,
I will try this with the 4.2.0 version of HumminbirdPC software and submit it as a bug if it happens.
Offline johno r
  • Unit(s): 798cxsi
  • Software: 5.840
« Reply #4 on: April 05, 2012, 03:30:22 AM »
I have the same thing going on with 4.1.8 Humminbird PC
« Reply #5 on: April 05, 2012, 03:26:00 PM »
It did the same on my PC with HumminbirdPC version 4.2.0 and I am still running an XP machine.  What version of Windows are you guys running?
If this was also in the 41.8 version of HumminbirdPC than not many folks must be using the “Add” function!
Offline johno r
  • Unit(s): 798cxsi
  • Software: 5.840
« Reply #6 on: April 05, 2012, 06:04:53 PM »
I am running xp as well
Offline LBloch
  • Software: 6.18
« Reply #7 on: April 05, 2012, 07:32:27 PM »
I run XP as well. My kid has Windows 7 on his lap top, I will try with that when I get a chance.  I was able to to do the add/replace with 4.1.8 and XP. I like the add/replace, it lets me put any combination of lakes on a SD card that I want, without making a new file in HumminbirdPC
« Last Edit: April 05, 2012, 09:05:59 PM by lbloch »
Offline LBloch
  • Software: 6.18
« Reply #8 on: April 05, 2012, 07:40:35 PM »
Didn't work with the 4.2 and Windows 7 either
Offline bobby
  • Unit(s): 1198 c Si & 997 c Si & X-17 LM
  • Software: 5.2
  • Accessories: weather sense, XM, live well water temp
« Reply #9 on: April 13, 2012, 12:15:33 PM »
This sounds like what is happening on my post, "Uploading brush pile gpx. files" sorry for the duplication. I am running the PC version 4.2 and have a windows 7 laptop, will be wathcing the progress here.
Last post June 19, 2009, 03:21:54 AM
by john h
Last post February 12, 2010, 08:28:01 PM
Last post October 19, 2010, 04:30:49 PM
by bruno.rosa
Last post November 04, 2010, 05:05:37 PM
by Wayne P.
Last post September 08, 2013, 04:36:30 PM
by maachuu
Last post August 18, 2014, 08:40:25 AM
by GFortelney
Last post May 29, 2015, 10:55:13 PM
Last post April 21, 2017, 04:10:22 PM
by Reelcrazy
