Author Topic: Update to 6.18 tracks are gone  (Read 13108 times)
Offline thunderbucket
  • Unit(s): 898cxsi
  • Software: 5.4
  • Accessories: GR50 and a non-working base map
« on: March 25, 2012, 11:02:15 PM »
I just updated from 5.5 to 6.18 on my 898, and lost all my google earth tracks I use to make lake outline maps  HB PC says all the points are there. Do I reinstall an earlier version or am I missing something?
Re: Update to 6.18 tracks are gone
« Reply #1 on: March 26, 2012, 09:22:43 AM »
Unless you intentionally deleted all NAV data, I would assume
that anything you had permanently saved would still be there.
I would turn your machine on and call HB customer support
and ask them to maneuver you through the menus to find
the saved tracks.
« Reply #2 on: March 26, 2012, 01:54:07 PM »
thunderbucket,
So after you updated the software on your 898 unit you downloaded the Nav Data to an SD memory card and than viewed that in HumminbirdPC, right?
« Reply #3 on: March 26, 2012, 05:42:24 PM »
There are issues with 6.180..
Can you go back 1 level until the 6.180 is fixed.
See if you have any problems then..
  • Unit(s): 898cxsi
  • Software: 5.4
« Reply #4 on: March 26, 2012, 09:43:11 PM »
Update:   ;D
Well i figured it out, tracks were there but not recognized, saved originals to a separate file and then ran them through gps babel into gpx.  upload them manually from each track to a group of tracks i created load into my 898 and voila.. success
« Reply #5 on: March 27, 2012, 12:15:19 PM »
Congrstulations on success..
I am a bit confused.  You had tracks before the uypgrade.  After the upgrade the tracks would not show.
I am confused as to why you had to use bable to convert.
Were the tracks from google earth prior or something else.
If this is all HB data I dont understand the tracks having to go thru bable....
Thanks, Chuck
  • Unit(s): 898cxsi
  • Software: 5.4
« Reply #6 on: March 28, 2012, 12:43:26 AM »
No it's google earth.  Using track points to make a lake outline as my part of Manitoba doesn't have mapping yet.  I upgraded from 5.5 to 6.18 also HB pc to 4.2  the waypoint management buggered up the Lake outline tracks not my trolling tracks.
Top it off with HB pc not having a add track button, it took a bit of playing around and ran my original kml files into gpx again and loaded each track manually into the group.  fixed my issue but the waypoint management is a royal pain in the ass
« Reply #7 on: March 28, 2012, 11:11:58 AM »
Thunder.  Thanks, now I understand the conversion.
Yep, waypoint management and tracks are a pain. 8)
Probably no end in sight as yet.. ::)
chuck
Offline LittleGazoo
  • Software: 3.640
  • Accessories: Ethernet
« Reply #8 on: April 22, 2012, 11:17:10 AM »
Yes
5.840/6.180 WMS has some track issues when you upgrade.  Your problem was my problem:
http://forums.sideimagingsoft.com/index.php?topic=3689.msg21791#msg21791
Last post August 15, 2010, 10:30:48 AM
by Wayne P.
Last post March 09, 2013, 09:45:28 PM
Last post January 24, 2015, 05:02:32 PM
by gimez
Last post September 07, 2015, 07:04:07 PM
by LittleGazoo
Last post July 28, 2016, 05:21:03 PM
by afaust
Last post May 16, 2017, 09:46:10 PM
Last post September 09, 2018, 08:09:50 AM
Last post June 15, 2019, 10:09:17 AM
