Author Topic: interlink disconnect - connected  (Read 12842 times)
Offline confusedfisherman
  • Unit(s): 787ci2, matrix 17, 798ci si combo
« on: March 25, 2012, 08:38:59 PM »
i am having problems with the interlink staying connected to my front 787c2i from the console 798cisi
i keep getting a pop up saying disconnected, then 1 second late its connected - it will do this all day long. connections are snug. i have both units with the latest updates. any clues?
Re: interlink disconnect - connected
« Reply #1 on: March 26, 2012, 01:46:17 PM »
Try going through the InterLink reset instructions here:
http://www.humminbird.com/FAQ.aspx?ContentId=3080
« Reply #2 on: March 26, 2012, 05:40:49 PM »
Was this working before?  When did it start doing this?
Are there any other issues with the units..
« Reply #3 on: March 26, 2012, 09:49:30 PM »
well, i just recently added it, so this was my first time out with it, that is about the only issue i have with the unit.
« Reply #4 on: March 27, 2012, 12:17:46 PM »
Try the reset option as Greg mentioned.
It should work right out of the box..
Unless the interlink/software has problems..
Sounds like the unit is ok though..
« Reply #5 on: June 02, 2012, 09:27:43 PM »
ok, maybe i am doing it incorrectly, i tried to repair as stated above but every time i try and connect the interlink it keeps popping up that interlink connection failed.
then its stars again interlink connected  and then is disconnected  again.  could it be there is a cable loose still? i have to boat in my driveway so it is not bouncing around.   any thought?
« Reply #6 on: June 03, 2012, 12:23:01 AM »
Is it possible that it's getting interference from something else on the boat?
Maybe re-check the wire routing.  Not sure if GPS could cause it, but I would try
and route the power wires away from GPS and VHF (if you have it).
« Reply #7 on: June 03, 2012, 01:25:28 AM »
nothing else on boat. no exterior gps, radio or anything.
Last post March 03, 2011, 02:32:45 PM
Last post December 27, 2011, 12:23:24 PM
Last post January 18, 2012, 05:01:22 PM
by havingfun2
Last post June 05, 2012, 01:28:20 PM
Last post May 03, 2013, 06:49:17 AM
by Muskyslayer96
Last post February 09, 2016, 01:34:58 PM
Last post October 24, 2017, 02:32:06 PM
Last post October 04, 2018, 06:08:04 PM
by Ed Knight
