Author Topic: benifits of units connected together  (Read 9414 times)
Offline noname
  • Unit(s): 1198c si 797c2
« on: February 26, 2011, 06:15:32 PM »
hi all a question for the ones who know. i have a terrova 101 with the universal 2. a 1198 si combo and a 797 c2. i want to connect these units together if there is a benefit to it. i need to know what will be connected to what. if you can get me on the right path i would appreciate it. thank you Rodger
Re: benifits of units connected together
« Reply #1 on: February 27, 2011, 08:54:39 PM »
Rodger,
Welcome to the forum.  The benefit would be the ability to share waypoints and gps.  You would be able to mark a waypoint on the 1198 while you are scanning and then be able to navigate to it on the 797.  You may not want to share GPS between the units if you have two transdcuers.  You want the GPS module to be as close as possible to the transdcuer the unit you are using is connected to.
The 797 does not have ethernet so you will have to use the Interlink module.
Hope that helps,
Offline Billn
  • Unit(s): 898c si, 788ci combo
  • Software: 5.210
« Reply #2 on: February 28, 2011, 10:09:26 PM »
Hello all, I am a newbie here, and have just gotten my new HB units.
I would like to connect the two, to share info (waypoints etc).
I have an 898c si and a 788ci  Combo.
 Which is the best avenue to go? I thought I read, the 788ci can do ethernet with software upgrade and an adapter cable. Or would Interlink be my best route?
Another question would be,  I plan on using the Lakemaster chip. Do I need one in eacch unit?
I think I have alot to learn! ;)
Bill
Offline stillbear
  • Stillbear
  • Software: 5.840 5.700- 4.0
« Reply #3 on: March 02, 2011, 06:59:40 AM »
Ethernet without a doubt. You will need to buy a card for each unit.They will not share lake maps yet. Gary
« Reply #4 on: March 03, 2011, 02:32:45 PM »
But only if that is a 788ci HD DI Combo or 788ci HD Combo unit.
If it is not an “HD” version 788ci unit you will have to use an InterLink connection.
Last post December 27, 2011, 12:23:24 PM
Last post January 18, 2012, 05:01:22 PM
by havingfun2
Last post June 03, 2012, 01:25:28 AM
by confusedfisherman
Last post June 05, 2012, 01:28:20 PM
Last post March 18, 2013, 09:03:57 AM
by Jim Jack
Last post March 22, 2013, 05:59:11 AM
by chuckauten
Last post April 19, 2013, 12:06:28 PM
Last post March 07, 2014, 02:07:06 PM
