Author Topic: Transducer rooster tail  (Read 36843 times)
Offline crappiefarmer
  • Unit(s): 798ci si
  • Software: 5.450
  • Accessories: none
« on: March 20, 2012, 12:22:00 AM »
Hello Guys. I'm new to the forum. Just recently bought and installed a 798 ci si and mounted the transducer on the transom of My bass boat. Everything worked pretty good except the rooster tail that the ducer is kicking up is hosing down my motor and could be a problem with it blowing water into my air intake  on right turns. I can't raise the ducer anymore because My jackplate will block the port side viewing. It is already messing with that side some. I will have to shave off a little of the plate to get a better shot for the ducer.
I have heard that some folks are making shields to knock down the spray when it is causing an issue like I am having. I would love any pics or descriptions that any of You have of Your shields or shields You have seen. My boat is a fiberglass Stratos bass boat. I have the ducer mounted directly on the transom, not on a piece of starboard. I can't set the transducer back anymore or the jackplate will become a bigger issue as it goes down pretty close to the bottom of the hull. I am working a fine line and looks like the shield will be my only option to get full performance of the unit and knock down the spray before it ruins my motor. Thanks for any help.CF
Re: Transducer rooster tail
« Reply #1 on: March 20, 2012, 12:37:36 PM »
CF,
Make sure that you installed the plug in the transducer for this.  There should have been a black rectangular shaped piece of material that installs in the open area between the transducer and the pivot arm of the mounting hardware.
« Reply #2 on: March 20, 2012, 01:09:43 PM »
cf, check (search) the forum for things like spray or shields  (be creative)
you will find some hits on this...
chuck
Offline coriobay
  • Unit(s): 898csi
  • Software: 6.1
  • Accessories: none
« Reply #3 on: March 21, 2012, 10:52:08 PM »
Hi Greg
do you have a picture of the rectangular plug, is it available online, i dont remember seeing one in the box
Offline Shooter00
  • Unit(s): 798c SI 788ci HD
« Reply #4 on: March 21, 2012, 11:47:10 PM »
Hi Greg
Nothing like that came with my 798 either....
« Reply #5 on: March 22, 2012, 09:30:23 AM »
I have heard from several folks who almost threw the plug away as it was not very appearent that it was a part of the install pieces.
If you cant find it call HB support and say the part was not in the box. Since this is a new unit..
Offline Roddy
  • Scan,scan and rescan
« Reply #6 on: March 22, 2012, 02:11:11 PM »
I installed one on the transducer mount, did not change a thing. The plug did not cone with any of my units,had to order it HB.
Scan,Scan and Rescan Roddy
Offline Shooter00
« Reply #7 on: March 22, 2012, 02:29:18 PM »
I called them and have one on the way.
Doesn't sound very promising but it was free.....
« Reply #8 on: March 22, 2012, 04:45:49 PM »
Hi Greg
Offline coriobay
  • Unit(s): 898csi
  • Software: 6.1
  • Accessories: none
« Reply #9 on: March 22, 2012, 05:09:29 PM »
Thanks for the pics Greg
i kept all the parts leftover from instalation, still have original box and  i definatly dont have anything that looks like that.
Getting one to OZ could be more trouble that its worth, anybody had sucess with it?
Offline RV Sam
  • Unit(s): 997c SI
« Reply #10 on: March 23, 2012, 03:40:17 PM »
Just wrap black electrical tape around and around the bracket and then put a tie stap to keep the tape from unwinding.  Did this 3 seasons ago and my boat stays in water for 6 months of the year.  Have not needed to touch it sense first doing it.
Offline coriobay
  • Unit(s): 898csi
  • Software: 6.1
  • Accessories: none
« Reply #11 on: March 23, 2012, 10:33:02 PM »
Just got the silicon gun out and filled the gap, Plan to test it this weekend
« Reply #12 on: March 24, 2012, 11:50:46 AM »
Now that is a good idea.  I would guess the silicone is a waterproof type and also not an adhesive
Offline jbrady2852
  • Unit(s): 999ci HDSI, 788ci DI
  • Software: 7.020
« Reply #13 on: July 02, 2014, 08:21:05 AM »
Do they make a plug for the 999ci SI.  I noticed when I lowered my transducer to get better reading it throws up water on the outboard?  If so how or who do i need to call?
« Reply #14 on: July 02, 2014, 01:56:28 PM »
No they do not jbrady2852.
« Reply #15 on: July 02, 2014, 06:09:01 PM »
I have seen some fabricate a deflector shield mounted above the xducer to keep the water spray from hitting the motor...
Offline flatcat_auz
  • ManWhore for Hire
  • Unit(s): 798CXI HD SI
  • Software: Version 6.250
« Reply #16 on: July 03, 2014, 05:04:10 AM »
Get an old thong (not that sort of thong u sick Americans :) )......cut to shape......jam in......silastic to complete......will try and add Pics......
Yup I got the international one, living in the land down under.....were women drink beer and men chunder.......and no piece of said plastic and had the same issue re:water and engine as yourself.....until the mighty thong came to the rescue
ManWhore for Hire.
Affordable rates.
Sorry No Seniors Discount.
Offline MTBob
  • MTBob
  • Unit(s): HB 998c
« Reply #17 on: July 08, 2014, 10:52:19 AM »
See photos - this is my attempt at taming the transducer spray.  It is a 1/4" piece of aluminum checker plate screwed to to the transducer mounting board.
However, I was having some issues with erratic depth readings and took it off to see if the issue cleared up.  I've run the boat with the plate off and the erratic depth readings seemed to disappear.  So, I'm going to put the plate back on and see if the depth reading issue returns.   I thought of using a plastic plate, thinking that the aluminum might somehow be interfering with the transducer signal.
Last post June 22, 2011, 02:25:43 PM
by Phiznat5000
Last post April 30, 2011, 09:22:30 AM
Last post May 20, 2011, 05:28:46 PM
by Roddy
Last post March 23, 2014, 01:56:00 AM
Last post October 13, 2014, 10:26:07 PM
by xSilmarilSx
Last post April 20, 2016, 10:04:42 PM
Last post September 02, 2016, 08:45:33 AM
Last post May 08, 2017, 08:34:39 PM
by fshndude
