Author Topic: Software release 6.180  (Read 24509 times)
« on: March 17, 2012, 09:57:54 AM »
Here is what I have so far on the 1st release of the 6.180 (by long name/unit).
If you have a code (6.180) that I dont list can you send it to me for inclusion in the downloads.
e91f7d44b67c40bb981d0c4538e030f5.bin   3/2/2012     1198
278dc4f848c449ce99ef64ca21f6b3c9.bin   3/1/2012     1197
407b11ffc5734ce19e1bebae3b7bd097.bin   3/??/2012    898
ae8b76db661e45d58134e3a420e2c92b.bin           3-14/2012    898  supposed to fix the 3/?? issues
d00e412da8e04a978c91b8d47386e61d.bin   3/14/2012    798
1992d7f33db740a5b03d50f031e454f8.bin   3/1/2012     998  waiting on a dowload
« Last Edit: March 17, 2012, 06:42:53 PM by sonar2000 »
Offline depark1
  • Unit(s): 998CX SI
  • Software: 6.180
Re: Software release 6.180
« Reply #1 on: March 17, 2012, 04:48:50 PM »
« Reply #2 on: March 17, 2012, 04:54:38 PM »
DP can you send it to me via www.transferbigfiles.com   and I will get it on the downloads.
chuck
« Reply #3 on: March 17, 2012, 05:28:33 PM »
Added to downloads in 898 today 3/17/2012
« Reply #4 on: March 17, 2012, 05:48:28 PM »
added today in downloads for 1198  this is the release 6.180
Offline depark1
  • Unit(s): 998CX SI
  • Software: 6.180
« Reply #5 on: March 17, 2012, 06:03:04 PM »
chuck
Can you PM me your e-mail address please?
« Reply #6 on: March 17, 2012, 06:16:00 PM »
Opppssssa sorry, forgot to add that.
ncurt100@gmail.com
Offline depark1
  • Unit(s): 998CX SI
  • Software: 6.180
« Reply #7 on: March 17, 2012, 06:17:27 PM »
I sent it to your email address.
« Reply #8 on: March 17, 2012, 06:38:08 PM »
Thanks, I will get it in the downloads.
Thanks for sharing with the group.
Modify:   got it and will get it to the downloads.  Thanks again for sharing with the group.
« Last Edit: March 17, 2012, 06:42:22 PM by sonar2000 »
« Reply #9 on: March 17, 2012, 07:10:03 PM »
OK, I have all of the following downloads completed today.
Thanks to those who sent me the needed files.
« Last Edit: March 17, 2012, 07:18:36 PM by sonar2000 »
« Reply #10 on: March 17, 2012, 07:19:57 PM »
Also need to verify if the two 898 downloads were for the USA or the international units...
Whew.  these downloads sure are curious..
Offline wolfs4evr
« Reply #11 on: March 17, 2012, 07:36:19 PM »
The ones I sent you are US.
Offline Enufzed
  • Enufzed
  • Oh happy days !!
  • Unit(s): 898cx SI
  • Software: V 6.180
« Reply #12 on: March 17, 2012, 07:47:30 PM »
Chuck,
The 898 update I sent you (if you got it) is the international version??  from the HB website which is available to all regardless of country. Put it this way my 898 unit is an international one but whether that makes any difference to the software updates I do not know.
Enufzed
Offline Enufzed
  • Enufzed
  • Oh happy days !!
  • Unit(s): 898cx SI
  • Software: V 6.180
« Reply #13 on: March 17, 2012, 08:25:51 PM »
Hi Chuck,
Just tried to update to the new available 6.180 and my unit says "6.180 already installed " and now can not update the new 898 file
1. Is it necessary to install the new 898 update.
2. What does the new versionupdate correct if anything.
3. Is it any different to the first available  6.180
Enufzed
Offline wolfs4evr
« Reply #14 on: March 17, 2012, 08:37:25 PM »
You have to revert your unit to the previous 5.7 update to install it.
Offline Shooter00
  • Unit(s): 798c SI 788ci HD
« Reply #15 on: March 17, 2012, 10:31:43 PM »
Chuck the update number is for the 5.840 for the 798.
I wish they would release  the 6.180 for the 798  :P
« Reply #16 on: March 18, 2012, 12:54:31 PM »
OK, let me check the downloads and make sure I have the right ones in the right place..
Are you saying the d00e412-----is actually 5.840.
 ::) darn.  this will really confuse me now.. :o
« Last Edit: March 18, 2012, 12:57:52 PM by sonar2000 »
Offline wolfs4evr
« Reply #17 on: March 18, 2012, 01:12:18 PM »
6d244b9892154170b6ce162f420f2459.bin that I sent you is the 5.840 update for the newer 798ci HD SI unit.
The 798c has a different update file number.
If that helps anything.
« Reply #18 on: March 18, 2012, 01:19:07 PM »
OK...I need a drink from the lake.. ::)
Call me at 252-430-7731 unless that is a long distance charge for you..If it is PM me your number and I will call you.  It is free for me..
Chuckl
« Reply #19 on: March 18, 2012, 01:36:06 PM »
New 6.180 list...(3/18/2012)
d00e412da8e04a978c91b8d47386e61d.bin   3/14/2012    798C  (non ethernet version) (5.840)
This is for the 798cihdsi and is 5.840
6d244b9892154170b6ce162f420f2459.bin                      798 CI HD SI  (5.840)  (Added)
« Last Edit: March 18, 2012, 02:56:31 PM by sonar2000 »
Offline walleyhunter
  • Unit(s): 1198c-si
  • Software: 6.180
« Reply #20 on: April 09, 2012, 08:16:26 PM »
i have a 1198c si with firmware 5.5, can I update to 6.18 with an SD card or will i have issues? Just am worried don't want to render my unit useless. Anyone update? Just looking for feedback from people that did.
thanks
Update decided to take the plunge and it works flawlessly. Updated by system being powered up and then putting in the SD card, used a 1G card. Double checked file size by downloading 3 times (OCD) :)
Nonetheless, thanks sonar2000
« Last Edit: April 09, 2012, 10:36:04 PM by walleyhunter »
Offline Irishrover
  • Unit(s): 997c SI Combo NVB and 898C SI Combo
  • Software: Navionics NVB
  • Accessories: Lakemaster Pro Map Wisconsin
« Reply #21 on: April 10, 2012, 01:19:59 PM »
Any news on the 997 getting the 6.180 version update? I see that the 998 got it. Is there a difference w/998 & the 997? Can I use the 998 6.180 version in my 997?
« Reply #22 on: April 10, 2012, 02:25:00 PM »
I have no idea if or when the 997c Si units will get the features in the 6.180 software update.
No, the software update for the 998c Si units will not work in the 997c Si units.  Each model units requires its own software update file and should not load the update file for another unit.
Offline Irishrover
« Reply #23 on: April 10, 2012, 03:02:20 PM »
Thanks Greg for the info
Offline rdstair
  • Unit(s): 1198C SI, 998C SI
« Reply #24 on: April 12, 2012, 08:07:08 PM »
Wallyhunter, what exactly did you do to update your 1198c SI. I have one also and was thinking about the update. Where did you get the file from that you used. thanks for the info.
  • Unit(s): 1198c-si
  • Software: 6.180
« Reply #25 on: April 12, 2012, 09:19:44 PM »
RDstair here is the instructions I followed, got the file off the downloads tab on this forum
You will need 2 things to do it the way I did. First is a formatted SD card. Second is a SD card reader/writer to USB for your computer. BTW make sure you are running windows XP or 7
1) Make sure you turn off your antivirus on your computer
2) download 1198c_6.18 file from SONAR2000 in the download section on this forum for the 1198C
3) save the file to your desktop
4) Plug in the USB adapter on the SD card reader/writer into your PC
5) insert in the SD card and format the card. I used a 1G card but I hear the High capacity 2-4 or 8G cards will work as well
6) right click on the 1198c_6.18 file on your desktop then (properties) that is on the desktop and verify that the file size is a total of 26.4MB- 27,664,330 bytes (this is important to make sure it didnt get stripped/changed during the save). Close file
7) right click on file again and send the file to the SD card drive.
8) open the drive that the SD card is on and verify the bytes size, if its the same you are good
Lastly, power up your 1198c-si. After it is fully loaded enter in the SD card. The system will tell you that you have xx firmware and are going to update to 6.18 do you want to do this? select yes the system will start loading the firmware off the SD card. After a minute or so it will power off the display and power back up to install the remaining firmware that needs to be loaded. Do not power off during this it will remind you as well.
The reason I like this method, is you 1) get the system powered up and 2) the system pops up a window asking if you want to load the firmware; it states the firmware you currently have and asks if you want to go to 6.18. This is extra security since it is reading the 6.18 from the card.
If you followed the instructions as above you will now be updated with 6.18 remove card and your done.
Questions let me know
Good luck.
« Reply #26 on: April 13, 2012, 09:36:43 AM »
good write up walley...I would add that it might be a good idea to restore factory defaults prior to inserting the sd card and after the update has completed...
HB is supposed to have written that into new updates but it does not hurt to make sure.
chuck
  • Unit(s): 1198c-si
  • Software: 6.180
« Reply #27 on: April 13, 2012, 11:06:46 AM »
chuck
 Yes, I agree restore the 1198 to factory defaults before and after loading the firmware. Not sure if this is needed, nonetheless,  it doesn't hurt to do.
Last post October 16, 2009, 10:42:10 AM
Last post September 23, 2010, 07:55:22 AM
Last post March 03, 2012, 03:59:47 PM
Last post March 19, 2012, 02:08:36 PM
Last post March 17, 2012, 10:51:52 AM
Last post April 09, 2012, 09:29:30 AM
Last post March 23, 2015, 04:13:56 PM
by sfw1960
Last post August 16, 2020, 02:37:18 AM
by ptgomes
