Author Topic: can't find export all nav data  (Read 21509 times)
Offline scoeri
  • Unit(s): 1197csi
  • Software: 4.750
« on: March 11, 2012, 03:31:13 PM »
i just installed software update 6.180 in my 1197si. now i can not find the menu to export all nav data as i have done in the past. what am i missing?
thanks,
scott
Offline SonarTRX
    • SonarTRX
  • Unit(s): 998c-SI
  • Software: SonarTRX
Re: can't find export all nav data
« Reply #1 on: March 11, 2012, 04:53:12 PM »
Quote
thanks,
scott
This functionality is available from the "Nav" menu, under "Waypoints, Routes, Tracks":
Move the cursor up to the "Options" item, press the right arrow buton and from there, you can:
"Select All and..."     Export (to MMC/SD card)
Tore
« Reply #2 on: March 11, 2012, 07:05:35 PM »
Tore is exactly right.  HB changed the menue and location that is all.  Still works fine from the new location/menu..
Chuck..
Offline scoeri
  • Unit(s): 1197csi
  • Software: 4.750
« Reply #3 on: March 11, 2012, 07:53:40 PM »
thank you so much. as usual, with me, it's operator error.
Scott
« Reply #4 on: March 12, 2012, 09:45:25 AM »
cant blame you when the old spot changes to a new menue.. :P
Offline reddog
    • My pictures
  • Accessories: Ipilot Link
« Reply #5 on: June 16, 2012, 11:20:14 PM »
How do you import data from one Humminbird to another.(new 998).. I exported the waypoints from the 397 to an sd card. When I put the card in, I couldnt find any place to import them.  I thought it was gonna be a plug and play import.  No?
Offline wolfs4evr
« Reply #6 on: June 17, 2012, 12:35:16 AM »
Turn the unit on first then insert the card.
« Reply #7 on: June 18, 2012, 02:29:52 PM »
Yep, that was a change with the last software update (well, the one before that on some units...).
Offline reddog
    • My pictures
« Reply #8 on: June 18, 2012, 02:57:20 PM »
Thanks wolf and Greg.
I got the data exported from the 597 onto an SD card. Then I fired up the 998 and inserted the card and it gave me a notice that the installation was successfully completed, but when I rebooted the unit, there  was no waypoints on my lake..  Any ideas?
« Reply #9 on: June 18, 2012, 03:54:41 PM »
Go into the waypoint management menus and see if you can find any of those waypoints.  Make sure that they are not set to hidden or in a group that is hidden.
Offline reddog
    • My pictures
« Reply #10 on: June 18, 2012, 11:07:45 PM »
I tried that, and couldnt find any waypoints, or groups.   its odd. its not that big of a deal for the guy that owns the unit, because I think he only had  6 waypoints in his 597. lol.. It still bugs me though when stuff like this happens,
« Reply #11 on: June 19, 2012, 10:12:17 AM »
Rollie,
Unless you loaded the waypoints when the unit was running in the default Simulator mode they should be in there somewhere.  ???
Offline reddog
    • My pictures
« Reply #12 on: June 20, 2012, 01:01:19 AM »
Greg,  The unit was on the boat at the time I loaded it with transducer and gps connected..  The 597 was on temporary power, and wasnt hooked up to transducer or gps though..
i did export my waypoints and trails from my 997 and was able to upload them into the 998, so I think if theres a problem, it may be on the 597s side, but its Ok, because that units going away..
I'm not going to send in the 998.  After playing around with it some more,(I think I explained it to you in a PM)  I am able to zoom in and out readily now. The zoom in button requires a little bit harder push than it should, but its been getting better with usage..
Last post May 13, 2010, 04:43:47 PM
by ZEUS
Last post September 21, 2010, 09:26:05 PM
by nediver
Last post March 06, 2012, 02:58:58 PM
Last post November 20, 2013, 05:27:51 AM
by lars
Last post January 08, 2014, 10:44:45 AM
by LittleGazoo
Last post January 20, 2015, 06:33:45 AM
by djherron
Last post May 29, 2015, 10:27:37 PM
by d.sonnenburg
Last post October 14, 2016, 09:18:15 PM
