Author Topic: Help to export and editing sonar data from a humminbird 597 ci Hd  (Read 14913 times)
Offline tiburon78
  • Unit(s): 1198 SI hd combo
  • Software: Humminbird PC
Hi,
I did a survey with a humminbird 597 ci HD and copied the data from the SD card to a pendrive. The file format is in HT? I dont know why but something went wrong?? I got the files in HT format?? Can you do a sonar mosaic from a 597 ci DI HD combo files??
Thanks!!
Re: Help to export and editing sonar data from a humminbird 597 ci Hd
« Reply #1 on: January 03, 2014, 12:16:55 PM »
Welcome to the Humminbird Side Imaging Forums Tiburon78.
When you did your survey, did you make a Sonar Recording or just a Track?  The *.HT files contain Track information.  Sonar Recording files should be in file folder labeled RECORD and will have the *.IDX and *.SON formatting.
Offline tiburon78
« Reply #2 on: January 05, 2014, 10:35:25 PM »
Hi,
I think I recorded just tracks. Another question how can I visualize HT files? cant open those with Humminbird PC...
Thanks a lot
« Reply #3 on: January 07, 2014, 01:28:20 PM »
You should be able to view a Track using Google Earth.
Offline rdstair
  • Unit(s): 1198C SI, 998C SI
« Reply #4 on: January 07, 2014, 11:16:58 PM »
using sim mode. can you make a recording to a sd card then transfer it to the computer and open it in contour elite to play with it?
Offline LittleGazoo
  • Software: 3.640
  • Accessories: Ethernet
« Reply #5 on: January 08, 2014, 10:44:45 AM »
HumminbirdPC can download Navdata contained in the MATRIX folder on the SD-card(which you should have exported from your unit).
MATRIX folder will contain HB's DATA.HWR and the nn.HT files.  DATA.HWR will contain waypoints and routes.  The .HT files will contain the saved-tracks.  One track per .HT file.
HumminbirdPC can also OPEN the individual HB .HWR and .HT files by using File>Open, then setting Files of Type box.  Choices are GPX files(*.GPX), Humminbird files(*.HWR, *.HT), Garmin files(*.GDP,*.MPS) or Lowrance files(*.LOW, *.USR).  You would change to Humminbird Files(*.HWR,*.HT), then you can select the desired .HT file or select multiple .HT files).
HumminbirdPC can then display the tracks in Google Earth.
« Last Edit: January 08, 2014, 10:46:25 AM by LittleGazoo »
Last post May 13, 2010, 04:43:47 PM
by ZEUS
Last post September 21, 2010, 09:26:05 PM
by nediver
Last post August 26, 2011, 05:21:17 PM
by stillbear
Last post September 14, 2011, 06:58:19 AM
Last post June 20, 2012, 01:01:19 AM
by reddog
Last post June 14, 2012, 11:53:23 AM
by fshndude
Last post May 29, 2015, 10:27:37 PM
by d.sonnenburg
Last post October 14, 2016, 09:18:15 PM
