Author Topic: Longer array and narrower beam  (Read 173524 times)
Offline wreckreationaldivers
  • Unit(s): 997si, 998si
Re: Longer array and narrower beam
« Reply #150 on: August 06, 2013, 03:43:05 PM »
Hi Rüdiger,
The cable is a CAT-6 type. Shielded twisted and 3x2Paare. Very good electrical. Values.
Cable diameter is 9mm, without supporting rope.
The connectors are LEMO and are pressure resistant up to 200m
But are relatively expensive, but the electrical properties are worth it.
LEMO S.A. USA, Sweden etc. Goooogeln
Greetings ....
Sea-Rover
what type of LEMO plug & sockets are these?
Cheers
Jeff
Offline Sea-Rover
  • Unit(s): 1198c / HELIX 12
  • Software: 6.610 / 1.940
  • Accessories: Towfish 115m Cable / Terraintool-3D, ROV
« Reply #151 on: August 07, 2013, 05:42:22 PM »
Hi Jeff,
Here are the order number for the LEMO connector:
FFA.3E.307.CLAC90Z and GMA.3B.090.DG
and counterpart
PCA.3E.307.CLLC90Z and GMA.3B.090.DG
Warning: Multipoleconnectors are fitted with hermaphroditic inserts including male and female contacts.
This is for a CAT-6 cable with a diameter of 9mm.
Cable diameters from 3mm to 15mm are possible for this connector.
Close to good assembly to 200m depth. With PUR shed without problems up to 350m.
with greeting
Bill
Last post November 28, 2011, 07:01:38 PM
by cds2
Last post December 29, 2012, 10:31:01 AM
Last post January 20, 2013, 03:10:23 PM
by whosmatt
Last post May 07, 2013, 03:05:02 PM
by Rickard
Last post April 21, 2014, 05:06:45 AM
by Pipe Rat
Last post January 28, 2015, 11:36:44 AM
Last post May 18, 2016, 11:46:36 AM
by sonarbear
Last post February 20, 2018, 11:16:06 AM
by Mark Saikaley
