Author Topic: 1197 downbeam kHz and screen waterfall rate  (Read 4494 times)
Offline habit_mapping
  • Unit(s): 981c, 1197c (2x) 1198c (2x)
« on: February 07, 2012, 12:30:06 PM »
Folks,
Can some explain the exact mechanisms that causes the screen "waterfall" (or clear rate) to slow by approx. half when the downbeam kHz is switched from 200 kHz to 83 kHz on an 1197c unit?
Much obliged.
Re: 1197 downbeam kHz and screen waterfall rate
« Reply #1 on: February 07, 2012, 12:53:53 PM »
HM, I am not sure what you mean by waterfall or clear rate. Can you describe this a little more...
I may be the 1% that is not up to date on terminology. ;D...... :P
Thanks..
« Last Edit: February 07, 2012, 12:55:16 PM by sonar2000 »
« Reply #2 on: February 07, 2012, 01:07:49 PM »
If you are meaning the rate by which the display gets updated, than this is due to the unit having to transmit and receive on two frequencies at the same time.  Even though you may set the unit to display only the 83kHz sonar frequency; it is still transmitting and receiving at the 200kHz frequency in order to determine the water depth.
« Reply #3 on: February 07, 2012, 01:42:06 PM »
Thanks. That answers my question.
Cheers.
Last post April 13, 2009, 06:12:57 PM
by Blackwaterkatz
Last post November 20, 2009, 01:53:19 AM
Last post April 21, 2010, 05:07:50 PM
by mendota
Last post August 03, 2010, 03:00:47 PM
Last post January 15, 2014, 09:51:53 PM
by ezfishn
Last post August 09, 2011, 04:05:44 PM
Last post January 17, 2012, 06:26:22 PM
Last post July 09, 2013, 08:42:12 PM
