Author Topic: ping rate  (Read 7323 times)
Offline goodwinexplorer
  • Software: 4.18
ping rate
« on: August 03, 2010, 02:35:39 PM »
how do you set the ping rate to auto and how do you turn off the low frequency?
Re: ping rate
« Reply #1 on: August 03, 2010, 03:00:47 PM »
I’m guessing that you are meaning the recording Pings Per Second menu setting here: go to the Snapshot and Recording View.  Open the X-press menu and the Pings Per Second menu should be at the bottom of the list.  Highlight the menu and use the Right Arrow button until the menu setting shows as “Auto”.
To turn off the lower frequency (assuming the 2D sonar here): go to the Sonar menu tab and set the Beam Select to the “200kHz” setting.
Last post April 13, 2009, 06:12:57 PM
by Blackwaterkatz
Last post January 15, 2014, 09:51:53 PM
by ezfishn
Last post August 09, 2011, 04:05:44 PM
Last post January 17, 2012, 06:26:22 PM
Last post July 09, 2013, 08:42:12 PM
Last post May 02, 2014, 10:29:24 AM
Last post January 28, 2015, 01:10:19 AM
Last post February 18, 2022, 09:41:22 PM
