Author Topic: 898c SI issue  (Read 9777 times)
Offline Cole
  • Unit(s): 898c
898c SI issue
« on: January 28, 2012, 08:58:32 AM »
Just got my new 898c SI hooked up. Only the left arrow key is working. Anybody ever have this problem? thx
Offline stillbear
  • Stillbear
  • Software: 5.840 5.700- 4.0
Re: 898c SI issue
« Reply #1 on: January 28, 2012, 10:38:20 AM »
Only one side works at a time will work. Hit menu key once should get an option right, left or both sides. Gary
Offline Cole
  • Unit(s): 898c
Re: 898c SI issue
« Reply #2 on: January 28, 2012, 11:05:22 AM »
When I do that it says Active Side Left but I can't change it to right or both because the other arrow keys are not working. Thanks for you quick response!
Offline Cole
  • Unit(s): 898c
Re: 898c SI issue
« Reply #3 on: January 29, 2012, 10:52:32 AM »
Still no fix. I'm guessing the key arrow pad is bad.
Re: 898c SI issue
« Reply #4 on: February 01, 2012, 12:59:32 PM »
Sorry I am late to respond here but have been busy at work.
It does sound like the keypad is bad.  Call Humminbird and set up getting your unit back in to be looked at and fixed. 1-800-633-1468
If you have not already done so be sure to sign up for the Humminbird Select program:
http://www.humminbirdselect.com/
Offline Cole
  • Unit(s): 898c
Re: 898c SI issue
« Reply #5 on: February 01, 2012, 01:30:48 PM »
It arrived in Alabama today. Thanks for your help.
Re: 898c SI issue
« Reply #6 on: February 01, 2012, 01:55:43 PM »
The 898's have had some key issues. So they should fix this for free. Usually their turn around time is good.
Last post November 20, 2009, 09:37:27 PM
by harry padgett
Last post January 02, 2010, 08:37:04 AM
by soretoe
Last post March 05, 2010, 07:17:43 PM
by joe p from mo
Last post July 04, 2010, 11:41:45 AM
by Vlad T. Impaler
Last post February 07, 2012, 03:48:48 PM
by nicknight
Last post June 15, 2012, 06:37:54 PM
by jsiegle24
Last post September 17, 2013, 12:24:07 PM
Last post August 22, 2017, 08:02:58 PM
