Author Topic: 997c transducer  (Read 9660 times)
Offline worm
  • Unit(s): 997c
997c transducer
« on: January 24, 2012, 10:23:28 AM »
Guys I just bought a 997c for saltwater use.. need help on SI Tranducer Mount on Back of Step Hulls... anybody installed a tranducer on a contender??
« Last Edit: January 25, 2012, 07:56:51 AM by worm »
Re: 997c transducer
« Reply #1 on: January 25, 2012, 06:34:49 PM »
worm I dont have any experience with a contendar.
I would suggest you browse the gallery and installation photos for anything that might be close.
I would also try a search argument for (be creative) transducer mounting or similar arguments.
There has been a lot posted on installs.
Offline Colt45
  • Action Craft
  • Unit(s): 998csi
  • Software: Navplanner
  • Accessories: Dual Beam
Re: 997c transducer
« Reply #2 on: January 30, 2012, 10:08:48 PM »
I have a 998c on a 2020SE Action Craft with stepped hull.  The SI transducer just could not be mounted where it would read at speed and still give a good side image.  I ended up buying a 2nd thru hull transducer for speed and stuck the SI on the left corner of the hull above the bottom line - it is out of the water when on plane - and use in for Left Side view only.  But then you don't need SI on plane.  The combination seems to work.  Still don't like the dim, hard to see screen.  Guess I'm just used to a Garmin.
Last post May 18, 2010, 06:45:51 PM
by Takman74
Last post June 16, 2010, 11:41:22 PM
by Sonartech
Last post October 28, 2011, 08:01:54 AM
Last post August 18, 2015, 02:31:01 AM
Last post November 24, 2015, 02:00:29 PM
Last post September 17, 2017, 06:04:58 PM
Last post May 05, 2019, 09:40:56 PM
by Delta Bass Fool
Last post April 14, 2023, 06:44:50 PM
by DiveExplorer
