Author Topic: 997c Transducer Failure  (Read 9936 times)
Offline noxpertjim
    • Bloomington-Normal Bass Club
  • Unit(s): 797c2i si combo NVB, 997c SI Combo
  • Software: 4.510, 4.570
  • Accessories: Weathersense, Interlink
« on: October 27, 2011, 10:16:42 PM »
After about 25 outings, the transducer mounted on my Skeeter gave up its fight.  My first hint was the depth reading of 2500+ feet in a lake with max depth of 35, and a quickly darkening sonar screen (I was in SI mode).  When I stopped the boat and followed the cable down, I knew there was a larger issue.  The cable was loose and didn't seem to be attached to anything.  Sadly enough, I was right.  (Photos of both the remaining part of the transducer and the resultant cable end below)
The worst part about this is, it's only about 8 months old (transducer only; the 997 has been with me for a couple of glorious years now) and it has, according to HB CS, ruined my 997 head unit.  I have no temp reading nor a readout for temp selection in the menus when I hook it up to my other boat's fully functional HB system.  They said I have to send it in for repair at a cost of ~$225.  Not to mention the cost of a new transducer.
No impact damage is evident on the leading edge of the remnants, and the day it failed I was several hours in to just open water running.
At least it happened on the outside of tournament season.
So, has this happened to anyone else and if so, were there other solutions than to send the head in to HB for repair?  I need a line on a good cheap source for another transducer, too...
Re: 997c Transducer Failure
« Reply #1 on: October 28, 2011, 08:01:54 AM »
Wow.
I've never heard of a transducer just coming apart like that.
Well,
The HB transducers are just made of plastic and can only take so much.
You obviously exceeded the limit.
I guess it depends on how fast you run and how low the transducer is to the
water.  The lower to the water, the more strain the tranducer is
going to be subjected to at high speeds.
I would suggest if you get another transducer, to mount it higher and/or to
slow down your speed.
You may also want to look into Airmar transducers.
They may be tougher than Humminbirds, I'm not sure, but unfortunately, they will
be more expensive.
Last post May 18, 2010, 06:45:51 PM
by Takman74
Last post June 16, 2010, 03:16:50 PM
Last post June 16, 2010, 11:41:22 PM
by Sonartech
Last post September 19, 2010, 10:16:25 PM
Last post January 30, 2012, 10:08:48 PM
by Colt45
Last post June 19, 2013, 09:17:00 PM
by SMA_TN
Last post May 05, 2019, 09:40:56 PM
by Delta Bass Fool
Last post April 14, 2023, 06:44:50 PM
by DiveExplorer
