Author Topic: Recommended accessories for a kayak install  (Read 10636 times)
Offline bigkahuna
  • Accessories: Custom ROV with Imagenex sonar
« on: January 12, 2012, 02:58:35 PM »
I'm going to order a new 798ci hd si this weekend to install on my 13 foot sit on top kayak so I'm going to need to buy a couple other things to make it work:
battery - I'm trying to decide between a 5 ah gel cell or a 7.5 ah SLA.  I probably won't ever paddle more than 3 or 4 hours in a row and only during daylight hours (so won't need the back light).
memory card - Only going to use it to record SI / GPS data to transfer to DrDepth.  4 GB enough?  What class should I get?
Thanks!
Offline SonarTRX
    • SonarTRX
  • Unit(s): 998c-SI
  • Software: SonarTRX
Re: Recommended accessories for a kayak install
« Reply #1 on: January 12, 2012, 05:31:59 PM »
Hi Big Kahuna,
I had an old UPS unit laying around, so i just bought a new, sealed, 12 Volt 7.2 Amp.Hr. battery that fit the UPS.
(The battery is a PowerSonic PS-1272 F2, and the UPS now serves as a charger...)
As a memory card, I use a 4 GB SanDisk Ultra II SD HC (15 Mb/s)
I have had no problems so far, using this card with a Humminbird 998c-SI
Tore
tore@SonarTRX.com
http://www.SonarTRX.com
Offline bigkahuna
« Reply #2 on: January 12, 2012, 06:18:07 PM »
Thanks Tore, exactly what I was hoping to hear.  Didn't realize you were in Honolulu.  The wife and I are from O'ahu.  Aloha, BigK
Offline xSilmarilSx
  • Software: 6.250 - 5.320
« Reply #3 on: January 14, 2012, 04:07:14 AM »
Since the 798SI need the backlight, more so in the sun, you need to take into consideration a power draw of around 0.8A/h for that unit..
I recommend the 7.5 Ah SLA battery
Offline bigkahuna
« Reply #4 on: January 14, 2012, 05:34:09 AM »
Thanks, didn't realize the amp draw was that high.  I'll go with the 7.5 ah then.
Last post July 26, 2010, 05:02:03 AM
by gobio
Last post May 12, 2011, 12:45:23 PM
by tfta
Last post July 17, 2012, 01:52:18 PM
Last post August 30, 2012, 08:34:27 AM
Last post October 02, 2012, 12:03:37 AM
by bbordeau
Last post August 14, 2014, 10:17:29 AM
Last post January 26, 2015, 01:02:35 AM
Last post November 11, 2015, 12:46:43 AM
by Bradaus1
