Author Topic: GPS failure  (Read 8336 times)
Offline rexico
  • Unit(s): 798 si combo --597 GPS
GPS failure
« on: January 11, 2012, 07:22:24 PM »
My new 798 gps worked the first day, then failed, then worked the next day then quit the third day any ideas?
RBYNNV
Re: GPS failure
« Reply #1 on: January 12, 2012, 09:13:01 AM »
Have you tried checking connections.  Could anything be blocking the receiver.....when you lose the gps what does the diagnostic screen display...
Re: GPS failure
« Reply #2 on: January 16, 2012, 04:26:11 PM »
Do both your 798c Si and 597 units use an external GPS Receiver?
If so, you can try connecting the 798 unit to the 597’s mount and see if the GPS will work or not.  That will help narrow down where the problem is.
Re: GPS failure
« Reply #3 on: January 16, 2012, 05:59:38 PM »
I think  the 597 is an internal GPS antenna...did this change?
chuck
« Last Edit: January 16, 2012, 06:01:02 PM by sonar2000 »
Re: GPS failure
« Reply #4 on: January 17, 2012, 10:13:57 AM »
chuck
Not sure Chuck but I thought that we may have made an external model 597 unit years ago.  I did not check but if we did and he has one; this would be a good way to check his 798c Si unit (unless he listed it wrong and it has an internal GPS Receiver as well).  If the 798 is an internal GPS model than the only thing to do is contact Humminbird and ship it in to be looked at.
Re: GPS failure
« Reply #5 on: January 17, 2012, 11:21:26 AM »
Thanks, I never saw a external mount. Might have been a promotion.
Last post June 16, 2010, 03:16:50 PM
Last post September 19, 2010, 10:16:25 PM
Last post October 28, 2011, 08:01:54 AM
Last post December 04, 2011, 10:02:21 AM
by Hawgeye
Last post February 16, 2012, 04:24:54 PM
Last post April 05, 2012, 03:05:04 PM
Last post February 26, 2013, 10:30:03 AM
Last post June 19, 2013, 09:17:00 PM
by SMA_TN
