Author Topic: Downloads  (Read 14568 times)
Offline neparon
« on: December 31, 2011, 05:03:22 PM »
    I just purchased a 798ci hd si from Cabelas, it has version 5.41. If I load 5.84 will that contain (5,500 & 5.590) or do I need to load each one? How old would this unit be with only the 5.41 loaded? Have a great NEW YEAR!!!!!!!!!!!!!!
Offline George
  • Software: Always up todate
Re: Downloads
« Reply #1 on: December 31, 2011, 06:18:15 PM »
neparon
You only need to apply update to the latest version.  Also, you should go to Humminbird Select and sign up, it will automatically extend your warranty for an additional year.
--> http://www.humminbirdselect.com/ <--
And last but not least go to go to --> http://www.dougvahrenberg.com/Videos.html <-- Doug Vahrenberg has a series of videos including a 9 part seminar which will help to get the most out of your new unit.
George
« Last Edit: January 09, 2012, 05:33:42 PM by George »
Re: Downloads
« Reply #2 on: January 04, 2012, 12:00:03 PM »
George gave you good advice neparon.
If you want to know how old your unit is just look at the serial number as it is date coded.  The first two numbers are the year, the next two are the month and the next two are the day of the month.  As an example: if your serial number was 12010305-0159 then it would have been produced on January 3rd of 2012 (yesterday!).  The other numbers represent the test station (05) and the sequential number of the unit that was tested at that station on that day (159th unit tested).
« Last Edit: April 26, 2012, 02:42:57 PM by sonar2000 »
Offline atexaspete
  • Unit(s): 798ci
Re: Downloads
« Reply #3 on: January 08, 2012, 04:23:26 PM »
George,
I went to the Humminbird Select and it only applies to 1100, 900 and 800 series units, not the 700 series.
Mike
Offline neparon
Re: Downloads
« Reply #4 on: January 08, 2012, 04:42:27 PM »
Thanks everyone for your help and info.!!!!!!!!!!!!!!!
       Have a great week!!!
Ron
Offline mcguire2093
  • Unit(s): 1197c si & 997c si
  • Software: 6.180 & 5.800
Re: Downloads
« Reply #5 on: January 09, 2012, 07:21:46 AM »
798ci doesn't have 5.84 in downloads.
Offline neparon
Re: Downloads
« Reply #6 on: January 09, 2012, 03:21:12 PM »
Under My Account @ humminbird.com they advised me to download version 5.84 and I completed the download. My unit is a 798ci HD SI.
http://www.humminbird.com/Faq.aspx?TaxonomyId=91A2904
« Last Edit: January 09, 2012, 03:24:41 PM by neparon »
Re: Downloads
« Reply #7 on: January 09, 2012, 03:56:44 PM »
If you are looking at this site, it is not here yet. Has not been uploaded.
It is available from HB as posted.
You should have registered your unit and have an account there.
Last post May 11, 2010, 09:18:37 PM
by bearpeter1
Last post May 15, 2010, 11:18:51 PM
by majflyboy
Last post March 08, 2012, 03:32:01 PM
Last post June 06, 2013, 08:29:19 AM
Last post April 15, 2012, 12:01:10 PM
Last post June 18, 2012, 01:30:12 PM
by Weekend Warrior
Last post April 30, 2013, 11:09:54 PM
by LittleGazoo
Last post May 05, 2014, 11:33:40 AM
