Author Topic: downloads have 4.3.8 on my unit 798ci i jest load up 6.3 or all others first.  (Read 7914 times)
Offline bigredeyebass
  • Unit(s): 798ci
hi I have 4.3.8 do I load 6.3 only or should I load up all others  ps I loaded  all the other downloads I mist.on my sd card or will my unit load up them in order.
« Last Edit: May 04, 2014, 10:42:00 AM by bigredeyebass »
The newest update is an accumulation of all previous update........You just need the most recent update.
Make sure you follow the procedure where you have the unit fully started up before you insert the update card....and make sure your power source is at full voltage and rock solid.
Bob B is right; you only have to load the most recent software update to get everything before it.  Do not have more than one software version on the memory card at a time or the results could be catastrophic!  The 4.3.8 is the HumminbirdPC program that is for your computer not the 798ci unit.
Last post July 18, 2010, 08:22:20 PM
by riven1950
Last post December 20, 2010, 10:11:06 AM
Last post April 01, 2011, 11:14:10 AM
Last post March 06, 2012, 01:25:37 PM
Last post May 21, 2012, 07:36:48 PM
by C. Corner
Last post June 28, 2012, 06:18:20 AM
by finalapproach
Last post July 09, 2013, 04:43:43 AM
by codking2000
Last post June 28, 2014, 07:59:26 PM
by bigwave800
