Author Topic: GPS connections with Explorer GX1600 VHF  (Read 13477 times)
Offline cosbyrec
  • CAPT
    • Captain Bob's Fishing charters, Inc.
  • Unit(s): 998C SI
  • Software: ?
« on: November 24, 2011, 08:52:15 PM »
I have a 998c SI and need to connect it to a Standard Horizon Explorer GX1600 VHF for DSC and MMSI purposes. The VHF has the following NMEA bare wires:
Blue-NMEA GPS Input(+)
Green-NMEA GPS Input(-)
Gray-NMEA DSC Output(+)
Brown-NMEA GPS Output(-)
I purchased the HB bare wire (AS-HHGPS) with wiring as follows:
Red-+12V
Black-Ground
Green-NMEA In
White-NMEA Out
How do you suggest I wire this up?
Thanks in advance.
Re: GPS connections with Explorer GX1600 VHF
« Reply #1 on: November 25, 2011, 10:53:03 AM »
I suggest that you try and send the AS-HHGPS back as you don’t need it to get the NMEA data from your 998c Si unit to the VHF radio.  All you need to do is use the wires at the end of the second cable that comes out of the GPS Receiver connector.  There will be either a Red, White and Black wire or a Green, White and Black wire.  The important wires are the White (NMEA Output) and Black (NMEA Ground) wires.  Be sure and tape off and secure the third wire so that it does not short to anything.  I believe that you wiring should be:
VHF Radio wires  -  Humminbird GPS Receiver wires
Blue (GPS Input +)  -  White (GPS Output)
Green (GPS Input -)  -  Black (NMEA Ground)
Since the 998c Si unit does not allow an input from a DSC radio the Gray and Brown wires from your radio will not be used.
FYI: The As-HHGPS would be used for an AIS communications connection.
Offline cosbyrec
  • CAPT
  • Unit(s): 998C SI
  • Software: ?
« Reply #2 on: November 25, 2011, 06:56:08 PM »
Thanks very much for the quick response. I'll give it a try.
Offline cosbyrec
  • CAPT
  • Unit(s): 998C SI
  • Software: ?
« Reply #3 on: November 28, 2011, 01:28:59 PM »
Connection was successful. Thanks again.
« Reply #4 on: November 28, 2011, 02:30:09 PM »
Cool!
« Reply #5 on: November 28, 2011, 05:08:02 PM »
The forum scores another hit.  Good for you guys...
Maybe we need a stat for problems solved... :P
Last post August 16, 2011, 02:36:10 PM
Last post March 15, 2013, 11:53:28 AM
Last post November 12, 2013, 10:55:45 AM
Last post January 21, 2015, 12:08:28 AM
Last post August 29, 2015, 10:44:00 PM
Last post July 04, 2016, 11:11:26 PM
Last post August 19, 2020, 06:34:58 PM
Last post August 18, 2025, 02:26:25 AM
by MarjanK
