Author Topic: New UK member saying "HI"  (Read 11463 times)
Offline Tony Bennett
  • Unit(s): 798CI HD SI
  • Software: 5.840
  • Accessories: none
« on: November 16, 2011, 08:32:15 AM »
Hi Folks
Been "lurking" for a while on your most excellent forum, whilst doing some research into what to buy before spending the pennies.  ;)
I've had a fishing buddy 110 for some time and was looking to upgrade.
The forum has been most helpful in making my decision.
Finally opted for a 798 CI HD SI  8)
As i have my own "Portabote" and also hire boats on the trout res'es - I have opted to put my transducer on a removeable bracket - sort of a G cramp that fits on the thwarts or the transom of the various boats I will be using, with a 22" (adjustable) pole going into the water on the bottom of which is mounted my tranducer. Expected top speed of the various boats is in the region of 8MPH only - 4HP outboards max.
Battery (fused) and 798 head mounted on a short wooden board which may be strapped to a boat seat for security and ease of removal.
Was wondering if any other member is using such a set-up and has any experiance based tips to offer for best performance ?
Thanks in advance ...... Tony
« Last Edit: November 16, 2011, 09:04:48 AM by Tony Bennett »
Offline Rüdiger
Re: New UK member saying "HI"
« Reply #1 on: November 16, 2011, 08:44:31 AM »
Hi Tony
Welcome in this forum  :D
mvh
Rüdiger
Finding is better than losing
« Reply #2 on: November 16, 2011, 09:02:28 AM »
Tony, we use the transducer mounted on a trolling motor shaft with a Johnny Ray bracket at the bottom.
Mounts to any boat and is depth adjustable..
  • Software: 5.840
  • Accessories: none
« Reply #3 on: November 16, 2011, 09:13:13 AM »
Thanks for the replies guys  8)
This link will show the transducer bracket I am using - Only slightly modified, as the angle bracket on this one is a little to small for the 798 transducer. Larger plate made and fitted.
http://www.thetackle-shop.co.uk/search_results.asp?section=93    .... then scroll down a little.
Appreciate your input ..... Tony
« Reply #4 on: November 16, 2011, 11:33:31 AM »
Thanks Tony.  wish we had know about that bracket and shaft before we made ours....
It should work just fine...
As we learned dont use above  5 MPH...
Let us know how this works for you..in different boats/setups.....
« Reply #5 on: November 16, 2011, 12:36:56 PM »
Welcome Tony.
I was wondering how you like your porta-bote?
There is a local lake close to home that only allows hand launched boats.
I took a hard look at a 12 foot porta-bote, but I haven't pulled the trigger yet.
Anything you really dislike about your porta-bote?
Thanks in advance.
  • Software: 5.840
  • Accessories: none
« Reply #6 on: November 16, 2011, 01:34:51 PM »
ITGEEK
Absolutely love my Porta-bote - had it for several years now, and altho' I'm 66, I can still, singlehandedly, assemble and launch it easily ;D
I am using the dolly wheels, and the slipway at my usual lake - but the short journey from the carpark to the jetty is still very managable, even fully loaded with all the gear for a days fishing.
Nothing that I actually dislike about the 'bote.
HTH ..... Tony
Offline Rickard
« Reply #7 on: November 16, 2011, 03:02:05 PM »
I have also used a 12 ft Porta-bote for a couple of years and I must agree with Tony, I love it! When I use it for side-scanning I never travel faster than 4 knots so my very simple removable bracket that is clamped between the gunwale and the tube along the lower part of the hull works well. At higher speeds (up to 14 knots with an old 3.9 hp 2-stroke and only me and no gear) I have to detach it.
Well, the price is a bit high, at least here in Europe.
Offline Koen Vandecauter
    • Hondengedrag
  • Unit(s): 798cxi SI HD
« Reply #8 on: November 26, 2011, 02:49:25 PM »
I also have a 12 ft porta bote and the 798 CI HD SI. My transducer is on a tite-lok transducer bar. I have a 6HP and even at full speed (20km/h) I have pretty clear readings, only little turbulence noise in the watercolum (motor side)....
Koen - Belgium
Last post March 10, 2010, 01:42:49 PM
Last post May 08, 2010, 10:42:51 AM
by stillbear
Last post May 27, 2010, 02:36:38 PM
by Jolly Roger
Last post September 02, 2015, 02:54:20 PM
by lolar3288
Last post September 17, 2010, 11:43:48 AM
Last post July 24, 2011, 11:15:15 AM
by gofission
Last post July 18, 2011, 11:45:16 AM
Last post November 28, 2011, 01:02:53 AM
by Roddy
