Author Topic: Changes position HDSi Sonar from the back in to the front of the boat  (Read 7011 times)
Offline Wylezalek
  • Zander-Fanatick
  • Unit(s): Humminbird 998cx-798c US
  • Software: 6.180-5.840
  • Accessories: Wetersene sandisk extr-32gb 16gb 8 gb
Hello,
can I change position HDSi Sonar from the back in to the front of the boat?
The Dual Beam SI works in the back from the boat.
I use the AS SILR Y side imaging splitter cable and the humminbird fishfinder 998c si.
Best regards
peter
Hello my hobby is a perch and his methods of fishing, Se Id Imagging Humminbird Forum, my passion is hunting for a record perch ,greet colleagues from our Humminbird forms.
Offline Rüdiger
Re: Changes position HDSi Sonar from the back in to the front of the boat
« Reply #1 on: October 24, 2011, 10:33:01 AM »
Hi Peter
The AS SILR Y cable separates Side Imaging into Left and Right Beams - for Side Imaging products only. Allows the use of two side imaging transducers with one unit without the need for a transducer switch. Used in applications where the a plastic thru the hull transducer is required on a boat with a deep V hull. Can also be used if the motor or other items on the exterior of the boat may block one side of the transducer and distort readings.
You need the AS SIDB Y cable - Side Imaging and Dual Beam - that allows you to use two transducers on one unit without the use of a transducer switch. For use with Side Imaging products only, in conjunction with a dual beam transducer only. For improved high speed performance for bottom tracking.
mvh
Rüdiger
Finding is better than losing
Last post March 15, 2011, 04:34:20 AM
Last post July 22, 2011, 11:21:09 PM
by stratofisher
Last post June 20, 2013, 02:03:11 AM
by D S
Last post March 12, 2014, 01:47:26 PM
by Tjo
Last post June 30, 2014, 02:19:04 PM
Last post March 30, 2015, 09:17:31 AM
Last post March 24, 2016, 10:44:00 PM
Last post April 18, 2017, 11:56:02 AM
by fshndude
