Author Topic: Case for my 798ci si  (Read 15310 times)
Offline jimbo
« on: August 10, 2009, 04:20:24 PM »
I got this from Amazon.com for $37. The Humminbird fits like a glove. The foam is pre sliced so you remove only what you need to.ila_renderedila_rendered
Re: Case for my 798ci si
« Reply #1 on: August 10, 2009, 04:50:08 PM »
Thanks Jimbo.  I have a 785c2 and needed just this for storage when not in use.  Thanks for the post!
« Reply #2 on: August 11, 2009, 03:57:59 PM »
And it’s yeller!  ;D
(old Humminbird color)
Offline jimbo
« Reply #3 on: August 11, 2009, 06:06:03 PM »
Greg,  What are the correct part #'s for a through hull Quad Beam transducer and Y cable to use with this unit? Thanx
« Reply #4 on: August 12, 2009, 11:12:47 AM »
Do you mean a True Thru-Hull transducer that mounts under the hull via a one-inch hole through the hull?  If yes than look at the XPTH-9-QB-90-T for the plastic version and XBTH-9-QB-90-T for the Bronze version.
If you meant the inside-the-hull type transducer than look at the XP-9-QB-90-T
You cannot use one of the Y-splitter cables with the QuadraBeam transducers (if you were planning on connecting it to the DualBeam side of this cable).  The way that the AS-Si-DB-Y cable is made it will not make connection to the extra side beams of the QuadraBeam transducer when it is connected.
[Now you could connect it to the Side Imaging side of this cable and it would only use the side beams and the temp of the QuadraBeam transducer.]
Last post November 10, 2016, 12:08:59 PM
by fshndude
Last post July 16, 2010, 02:40:02 AM
Last post July 25, 2010, 12:37:59 PM
by Chiboo
Last post December 12, 2010, 09:59:42 PM
by Stumpy
898 case
Started by 1966g3 898c SI
Last post February 19, 2012, 02:21:13 PM
Last post July 11, 2012, 04:54:29 PM
by Speedtroller
Last post May 19, 2014, 04:36:40 PM
by bigredeyebass
Last post February 17, 2015, 09:40:48 AM
by bobbyb
