Author Topic: water temp  (Read 7940 times)
Offline gaj
  • Unit(s): 898 c si,858c
water temp
« on: August 03, 2011, 06:43:03 AM »
cant find my water temp reading on my 898si or my 858c help!
Offline calli1
  • Unit(s): 1198 S I & 787c2i
Re: water temp
« Reply #1 on: August 03, 2011, 08:09:23 AM »
I guess you have already gone through your "select readouts" and looked for it.  Now, if you have a seperate temp probe, it may not be hook up or come unloose.  It could also be your transducer on one of the units if you are sharing.  Go through your diagnostics and check making sure everything is connected.  Power your unit off and on.  Also try under the similator mode.  I have found with my 1198 that my depth reading doesn't show until my transducer hits some water.  Just a few tips.  Good Luck.
Re: water temp
« Reply #2 on: August 03, 2011, 05:16:16 PM »
Which transducer do you have?
Last post May 01, 2012, 12:52:17 PM
by xSilmarilSx
Last post June 28, 2012, 07:29:20 PM
Last post May 22, 2015, 01:17:41 PM
Last post August 11, 2015, 09:19:37 AM
Last post September 11, 2015, 06:42:58 PM
by snowman48047
Last post August 30, 2019, 12:43:39 AM
Last post December 18, 2020, 10:28:00 PM
