Author Topic: split screen readings  (Read 10639 times)
Offline T.G
  • Unit(s): 898si
  • Software: v 6.180
« on: July 27, 2011, 12:07:01 AM »
hi all, this maybe a stupid question but in the split screen mode with 2d /down scan,does the image start again on the 2nd screen or is it still scrolling across from the 1st half of the screen?
Re: split screen readings
« Reply #1 on: July 27, 2011, 10:49:53 AM »
I think the images are independent of one another.
Each type of image stays in the same position on the screen.
In other words, the 2d part acts just like 2d if it was only on one screen but it takes up the left half of the screen.  It will stay at the left half of the screen until you change the view.   As far as scrolling, newer information is always at the right and older information gets scrolled to the left.
I hope this helps.
« Last Edit: July 27, 2011, 10:51:42 AM by ITGEEK »
« Reply #2 on: July 27, 2011, 05:49:03 PM »
ITG is right .....the two screen are seperate displays.  so boths screens are concurrent displays...
Offline T.G
  • Unit(s): 898si
  • Software: v 6.180
« Reply #3 on: July 28, 2011, 07:20:01 PM »
great thanks guys thats what i thought ,it was just with using the DI & 2D split screen, the DI was showing stuff that the 2D didnt & had me a little confused.
« Reply #4 on: July 29, 2011, 08:59:32 AM »
They will show different stuff and the same stuff differently.  This is due to the different shape and size of the sonar beams.
« Reply #5 on: July 29, 2011, 09:48:34 AM »
DI and 2d are two different display types. You will see things differently and in some cases not the same thing. but the sonar beam is under the transducer so it is scanning in and for the most part the same area...
Offline T.G
  • Unit(s): 898si
  • Software: v 6.180
« Reply #6 on: August 07, 2011, 04:41:55 AM »
thanks for the replies guys,just got to get out & use it more,ive been too bust fishing from the hobie instead!
Last post December 14, 2009, 10:31:30 AM
Last post March 08, 2011, 08:20:37 PM
Last post March 21, 2013, 07:18:27 PM
by Trytoofish
Last post May 24, 2011, 02:29:34 AM
by johno r
Last post April 13, 2013, 12:13:38 AM
by Gimp
Last post December 12, 2013, 10:09:04 PM
by godwinrl@hughes.net
Last post December 20, 2013, 12:45:54 AM
by vik33
Last post September 27, 2015, 05:38:29 PM
by nwifishnut
