Author Topic: using standard transducer as a shoot through?  (Read 8566 times)
Offline gros21
  • Unit(s): 1197
  • Software: latest
« on: July 07, 2011, 05:22:47 AM »
ive got a kayak and just ordered a 898Cx (international version) i have heard rumors that it will work can any one confirm this. It a ocean kayak 4.5 elite so its a plastic hull. not metal or thick glass
Re: using standard transducer as a shoot through?
« Reply #1 on: July 12, 2011, 09:58:52 AM »
The HDSi transducer will not work as an inside-the-hull application due to the Si sonar beams radiating directly out of the sides of the transducer.  You would have to mount the standard transom mount HDSi transducer on the outside of the hull or use an XPTH-9-HDSi-180-T transducer which is a true Thru-Hull transducer.  This transducer mounts through the hull via a hole in the hull.
Now if you are also getting a DualBeam only (2D only sonar) transducer than yes they will work as an inside-the-hull transducer.  I suggest you look at using our MHX-XMK Kayak Mounting Hardware for this.
Last post April 14, 2010, 02:45:32 PM
Last post March 29, 2012, 10:08:32 AM
Last post October 30, 2012, 01:51:28 PM
Last post May 30, 2013, 05:14:51 PM
by RBrad
Last post May 20, 2013, 05:30:40 PM
by promapper
Last post February 20, 2015, 04:04:47 PM
Last post March 25, 2015, 11:39:15 AM
Last post February 19, 2017, 06:08:06 PM
by 362 ranger pilot
