Author Topic: New Hot Maps SD card.. 1197si installing instructions needed..  (Read 13288 times)
Offline Bassmannnnn
  • Unit(s): 1197si/937c
I just purchased a Navionics Hot Maps East SD card, wanted to check here first before loading it into my 1197si , any instructions that I might need,,
All advice is welcome.. Thanks you..
« Last Edit: June 22, 2011, 05:06:12 PM by Bassmannnnn »
Offline Del
  • Unit(s): 1197 SI
Re: New Hot Maps SD card.. 1197si installing instuctions needed..
« Reply #1 on: June 22, 2011, 04:34:49 PM »
Plug the card into your device and power it on ;)
If you're on the water recording data, take care you dont save the records to your navionics card (the device will show a warning to you) if its not write protected.
The map wont be "installed" it's just loaded from the card. If you unplug the card the device will unload the map and you're back to basic map. Actually it's pretty simple.
Greetings,
Del
Offline Bassmannnnn
Re: New Hot Maps SD card.. 1197si installing instructions needed..
« Reply #2 on: June 22, 2011, 05:09:18 PM »
Does this card automatically go to the lake unit is on? Can other lakes be previewed before actually going there?  :-\
Offline Del
  • Unit(s): 1197 SI
« Reply #3 on: June 22, 2011, 05:39:11 PM »
If you turn your device on, the whole map will be loaded and viewable. Your unit will show your current gps position first but you will be able to zoom in and out and move your cursor around the whole world. The area covered by your navionics map will include more detailed informations (which are loaded from the plugged-in navionics card(s)) than the base map.
To be honest, just plug the cards in and start playing around with your unit. Theres a lot to learn and discover ;)
Greetings,
Del
« Reply #4 on: June 22, 2011, 05:52:57 PM »
Del, does the whole map load or in reality load a portion relative to your position.  Unless you use the cursor to go to another area.
If the whole map loads then what a waste of memory. If this is the case no wonder some folks have problems with the units. Not enough menory??????
Offline stillbear
  • Stillbear
  • Software: 5.840 5.700- 4.0
« Reply #5 on: June 22, 2011, 06:32:52 PM »
Chuck it loads as you go an change positions. Gary
Offline Del
  • Unit(s): 1197 SI
« Reply #6 on: June 22, 2011, 06:34:24 PM »
Actually what i've just wanted to make clear to him is that he will be able to access the whole map-covered area. The software isnt just making the parts avaliable to him which are close to his gps position.
I actually got no clue if the maps are completly loaded into memory, from experiences with my 1197c SI it doesnt "feel" like doing so.
« Reply #7 on: June 22, 2011, 06:39:52 PM »
Gary and Del....Thanks...
I dont use the maps very much on the HB.....just the sonar...
I know in other units "maps" are quite large and page in sections as you either move on the map or change position with the cursor.
I will have to try sometime to see if there is a prompt like inother units that signal loading as the map is paged...
Isnt it amazing how all these devices do the same thing differently....
Offline Bassmannnnn
« Reply #8 on: June 23, 2011, 05:20:17 AM »
Thank you so very much for your expertise.. This site is a blessing for us learning the units..
THANK YOU!!! ;)
Last post December 15, 2009, 10:38:32 PM
Last post January 11, 2010, 10:55:19 PM
by lcookie
Last post April 10, 2010, 05:12:18 AM
by keizerh
Last post May 12, 2010, 12:49:54 PM
Last post November 08, 2011, 11:22:46 AM
Last post April 11, 2012, 02:02:57 PM
Last post December 23, 2014, 08:30:33 PM
by gregghainen
Last post May 22, 2016, 05:39:26 PM
