Author Topic: 1197si No Depth on screen  (Read 11202 times)
Offline scrimshaw
  • Unit(s): 1197
« on: May 16, 2016, 12:56:06 PM »
I recently installed a new transducer transom mounted and ran the wire up to Y connection. When I power up the unit the Depth does not show up on the head unit. The readouts along the bottom of the screen do not include depth although I have set it on the menu.
Re: 1197si No Depth on screen
« Reply #1 on: May 16, 2016, 03:45:28 PM »
Sounds like the system isn't seeing the 2D element ..... need more details about what transducer you installed.  Did you add a 2D to the transom or a new SI?
What was your reason for the new transducer?
Offline scrimshaw
  • Unit(s): 1197
« Reply #2 on: May 16, 2016, 06:53:10 PM »
I installed a new SI transducer on the Starboard side as the old one failed at the seam and began to separate.
« Reply #3 on: May 16, 2016, 08:25:12 PM »
So .... do you have 2 SI transducers?  One for each side of the boat?
I would try to connect the new right side transducer directly to the unit and see what you get.
Offline scrimshaw
  • Unit(s): 1197
« Reply #4 on: May 16, 2016, 08:37:59 PM »
There are 2 SI transducers one on each side. I will try direct connection. Still wouldn't the screen Depth readout box be on the display. It does show temp.
« Reply #5 on: May 16, 2016, 09:23:44 PM »
I may have mis-interpreted your post ..... If you display the 2D on your unit, do you get a correct bottom reading .... does the SI and display of the water column work correctly?
I was thinking your 2D wasn't working, and you may just have a readout problem.
Offline scrimshaw
  • Unit(s): 1197
« Reply #6 on: May 16, 2016, 09:30:30 PM »
My problem is the screen does not display depth at all the view is not present but is selected on the menu.
« Reply #7 on: May 16, 2016, 09:37:35 PM »
i'm wanting to make sure your 2D transducer is working correctly ....If you go to a standard 2D sonar view, do you get a good bottom reading?  This won't work right if not in the water.
Offline scrimshaw
  • Unit(s): 1197
« Reply #8 on: May 22, 2016, 11:10:12 AM »
wonderful thing happened when I put the boat in the water , no more problems.
« Reply #9 on: May 22, 2016, 05:39:26 PM »
Thanks for letting us know.
Last post December 15, 2009, 10:38:32 PM
Last post April 10, 2010, 05:12:18 AM
by keizerh
Last post June 30, 2011, 02:53:40 PM
Last post June 23, 2011, 05:20:17 AM
by Bassmannnnn
Last post November 08, 2011, 11:22:46 AM
Last post October 25, 2014, 02:56:14 PM
by DiveExplorer
Last post December 23, 2014, 08:30:33 PM
by gregghainen
