Author Topic: 898c SI Powering down sequence  (Read 18702 times)
Offline Helge23
  • Unit(s): 898c SI
  • Software: 5.500
« on: June 21, 2011, 01:53:08 PM »
Anyone else having issues with powering down the 898c SI? Most often, I have to repeatedly hit and hold the power button in order for it to power down. One would think the first time you push and hold it for the 3 second countdown it should work but it doesn't. Any causes?
Thx in advance.
Re: 898c SI Powering down sequence
« Reply #1 on: June 21, 2011, 02:05:30 PM »
If you are firmly holding the power button in for the required time, than it should be shutting down.
Does the powering down in 3 seconds message show the whole time that you are holding down the power button?
Maybe you got an intermittent power button?
Offline edwardpic
  • Just fish....No excuses
    • My Company
  • Unit(s): 898c and 1198c
  • Software: 5.500 and 5.500
« Reply #2 on: June 21, 2011, 02:15:28 PM »
Mine does the same thing....Sometimes I have to rock the power button while holding it down to shut off....My 1198 doesnt do that....I need to send mine in to be fixed but trying to pick a week that I dont fish
Big E
Offline Helge23
  • Unit(s): 898c SI
  • Software: 5.500
« Reply #3 on: June 21, 2011, 03:29:27 PM »
The "Powering down in 3 seconds" does not always come on but I do hear a beep when I press the button. Sometimes it starts to countdown...then it disappears.
« Reply #4 on: June 21, 2011, 04:24:10 PM »
I seem to recall some issues with the power button (switch) in past conversations. I dont think this is a severe quality issue, none the less one that is or has had some problems. Possibly a cycle of parts in the past. More so for the "98" series of units than others..
I would contact HB cust support and see about an RMR for repair.
This of course willl require you giving up the unit for a short period of time.... :'(
The power switch is the only "key" on the units I have seen or heard of possible problems.
Offline edwardpic
    • My Company
« Reply #5 on: June 21, 2011, 04:36:14 PM »
I just called and got my RA#...will be sending mine in to be fixed under warranty....Ill have to pick a weekend i dont want to fish.....
Big E
« Reply #6 on: June 21, 2011, 05:58:27 PM »
OK< hope this does not take too long.........
Let us know when you get it back and any information they may send along..
Offline edwardpic
    • My Company
« Reply #7 on: June 22, 2011, 08:01:18 AM »
Chuck....i was told by HBS that it was a known issue on some models...Luckily Im sending it too them next day air(my company account) so the turn around should be quicker...Ill definately post how it went and what if anything was said...Tarpon this weekend so im shipping it next Monday
Big E
« Reply #8 on: June 22, 2011, 02:26:19 PM »
I really think it was a bad batch of switches.  Any way  catch the big one and then get the unit in for repair.. ;D
Offline neilbober
  • Unit(s): 898c SI
« Reply #9 on: October 29, 2011, 11:26:12 PM »
Humminbird repaired my 898 for the exact same issue....no problems. Works great now.
« Reply #10 on: October 30, 2011, 11:26:34 AM »
Great....now to get on with the fishing... ;D
Offline sixonfloor
  • Unit(s): 798, 898
« Reply #11 on: March 12, 2012, 11:31:51 AM »
I had the intermittent Powering Off problem when I first got my 898. I sent it in for repair under warranty and it still has the same problem. Humminbird could not find anything wrong with the unit. I have just learned to live with the problem... sometimes it shuts down on the first try... other times it takes 2 or 3 tries at holding the power button down until the unit decides to shut down.
Offline wolfs4evr
« Reply #12 on: March 12, 2012, 01:51:27 PM »
My 898 does it too.  Not too bad though.  As long as I don't mash the button it shuts off/starts the countdown almost every single time (nice easy push of the button).  Mash it and it is hit and miss.
« Reply #13 on: March 14, 2012, 12:10:45 PM »
That may be what a lot of users are running into here: they “mash” the power and other buttons.  When they do this the contacts inside the unit get deformed and do not close the switch.  An easier press of the button may work better.
« Reply #14 on: March 14, 2012, 04:47:36 PM »
Any chance of getting a stronger switch.  This should not happen..unless you hit it with a hammer..
« Reply #15 on: March 15, 2012, 11:45:43 AM »
These are not the mechanical type of switch that you are thinking of Chuck.  Basically behind the button is a pillar of material that has a contact on it that mates with a contact on the PCB.  If the button is pressed downwards past the contact point, or if it is not pressed directly downwards, the two contacts do not always mate.  This results in a button that does not appear to work.  Most of the time if you use a lighter touch the buttons work fine.
« Reply #16 on: March 15, 2012, 03:03:05 PM »
I understand these circuit board switches, but still they should work with a strong push.  Again, dont hit it with a hammer is all...
They are similiar to your keys on the computer keyboard.  You can hit them fairly hard with out causing a problem..
« Reply #17 on: March 16, 2012, 04:50:38 PM »
As long as it is a straight strike they will work.  Problem is when folks start ‘mashing’ buttons they tend not to do so in a straight line with the button.  I didn’t believe this until a saw a live demo of this.
« Reply #18 on: March 16, 2012, 04:58:41 PM »
Maybe a more forgiving switch is needed.  Like other computer devices have...
A strong push should be accepted.  If you wack the key then it probably will have a heart attack..
Offline Helge23
  • Unit(s): 898c SI
  • Software: 5.500
« Reply #19 on: May 08, 2012, 04:49:51 PM »
I received my unit back after sending it into HB back in March...wow..turn around was only 5 days!! Now that's customer service! I installed the unit and powered up & down several times with no issue. And to add to the previous comments, I was pressing the button the same way I did when I started to find problems with the orginal switch. Not mashing it or pushing it at an angle.
If the switch is designed to only function properly when pressed exactly straight and with "x" amount of pressure, then it's designed wrong for a consumer product...in my opinion. I am an electrical engineer by trade and was surprised to hear that the switch was that finicky. As Chuck stated, the switch should be more forgiving...assuming it's a quality switch.
« Reply #20 on: May 09, 2012, 12:59:54 PM »
You would think that since the 898c is one of the newest units,
that Humminbird would have improved the switch over
older models, or at least maintained the previous quality.
Not good to see switch problems in newer units.
Could mean they are saving some coin by using cheaper parts.
« Reply #21 on: May 09, 2012, 02:11:48 PM »
ITG,
The 898 units use the same switches as are used in the other 800 series units, the 958c, 958c DI, 998c Si and (at elast) the 1158c, 1158c DI and 1198c Si units (not sure about the older 1100 series units).  I don’t think that we have been hearing from the owners of the other units as much.  I’m thinking that Chuck may be right in that this was related to a batch of switches.
Got my switch types wrong on these units: they are a mechanical type switch but still use a stem type button to actuate the switch.
Last post March 14, 2012, 01:04:48 PM
by Moose1am
Last post February 15, 2013, 09:53:50 PM
by bear
Last post September 07, 2011, 08:23:17 AM
by Chad711
Last post February 06, 2012, 11:49:31 AM
by George
Last post September 29, 2013, 12:29:19 AM
by cjbfisher
Last post June 16, 2014, 05:43:37 PM
by MadTownGator
Last post November 12, 2015, 08:22:00 PM
Last post December 19, 2016, 01:52:21 PM
by Baker11
