Author Topic: powering unit for update question  (Read 8755 times)
Offline rovaline
  • rovaline
  • Unit(s): 997 csi
  • Accessories: 5.840
« on: February 06, 2012, 09:13:51 AM »
When using an sd card to update a unit is it ok to power the unit up on the boat while doin the update
Offline George
  • Software: Always up todate
Re: powering unit for update question
« Reply #1 on: February 06, 2012, 11:49:31 AM »
rovaline
Yes, this is the only way I make my updates.
I upload the new update on my SD card making sure there are not any other updates on the card.
First I turn on my unit and then restore it to the original settings by using the restore menu item.
Then I shut down my unit and insert the SD card with the latest update and turn on the unit and follow the instruction which is basically to do nothing until it completes its task.
Do not try to intervene even if you forgot to restore the unit most of the time you will get away with it, but if you shut it down midway it will cause you some grief.
Over the past 2 years I was in a hurry twice and did not restore my unit and got away with it, some some folks have had problems.
George
« Last Edit: February 06, 2012, 11:51:55 AM by George »
Last post March 23, 2010, 10:16:17 AM
Last post February 16, 2011, 09:16:48 PM
by lcookie
Last post September 06, 2011, 09:52:39 AM
by Double Digit
Last post November 08, 2012, 08:40:34 AM
Last post November 05, 2013, 12:02:52 AM
by CHOOhonets
Last post February 17, 2014, 07:46:40 PM
Last post June 17, 2014, 01:16:10 PM
