Author Topic: help with seeing fish.  (Read 14607 times)
Offline dgreenhill
  • Unit(s): 2
  • Software: 5.2
« on: May 25, 2011, 07:54:38 PM »
I'm new with si and not sure what bass look like on the bottom.Any suggestions or tips on seeing them on bottom while ledge fishing. :-\
Offline jimf
  • Unit(s): 997ci si
Re: help with seeing fish.
« Reply #1 on: May 26, 2011, 02:10:17 PM »
do you want to know what a fish looks like on side image ?
Well, I can't tell you if it was a bass or walleye but a gamefish looks like a small ovel shape white gost. I mean do you know what a white rice looks like ? well that is what you will see on the side image screen and it will be to the left or right side of screen because the fish will move to the sides of the boat as you pass them. That is if you have a gas motor on. If trolling motor is on then they can be any place on screen.
hope this helps.
Jim
Offline 96720
  • Unit(s): 998c si
  • Software: v5.410
« Reply #2 on: May 26, 2011, 02:55:17 PM »
Not bass but some striped mullet hanging by a submerged tree.
Offline jimf
  • Unit(s): 997ci si
« Reply #3 on: May 28, 2011, 06:49:33 PM »
what do you have your down image width set on ? I mean is it narrow/middle/wide setting ?
JimF
Offline dgreenhill
  • Unit(s): 2
  • Software: 5.2
« Reply #4 on: May 30, 2011, 08:10:30 PM »
I usually run the si about 60 ft to both sides.
Offline jimf
  • Unit(s): 997ci si
« Reply #5 on: May 31, 2011, 09:21:29 AM »
I didn't mean the side image. I mean the down image part. The sonar that looks down and its part of the down image.
There is a setting for narrow/wide/ ?
Offline 96720
  • Unit(s): 998c si
  • Software: v5.410
« Reply #6 on: May 31, 2011, 05:07:06 PM »
The DI width was set at narrow in the snapshot.
Offline jimf
  • Unit(s): 997ci si
« Reply #7 on: June 01, 2011, 08:50:31 AM »
thanks
Thats were I have my set at also. The picture looks clearer in narrow setting then the wide setting.
Last post May 17, 2015, 08:52:36 PM
Last post July 22, 2014, 08:39:08 AM
Last post September 10, 2014, 12:23:19 PM
Last post October 19, 2014, 08:51:51 PM
Last post April 16, 2015, 08:59:28 AM
Last post August 19, 2015, 12:28:24 PM
by smallstk
Last post April 17, 2017, 12:14:44 PM
by fshndude
