Author Topic: 1197 5.500 update  (Read 38110 times)
Offline indiana 520
  • Unit(s): 1197 c si
1197 5.500 update
« on: May 18, 2011, 03:34:19 PM »
just installed the new 5.500 update on my 1197 and now my color pallet on the side imaging view only shows blue. try to change it to amber or any other color and its black. what now.
all i know is i didn`t have this problem before i downloaded the upgrade.
« Last Edit: May 18, 2011, 06:17:00 PM by indiana 520 »
Offline raricker
  • Unit(s): 797c, 998c
  • Software: 5.450, 6.490
  • Accessories: weathersense, aux speed,GRHA
Re: 1197 5.500 update
« Reply #1 on: May 18, 2011, 05:29:13 PM »
Hi,
I've been doing some testing on the 5.500 release for my 998c and your post caught my eye.  For my testing I have (again for my 998c) four revisions (4.970, 5.210, 5.410, and 5.500) across two MMC/SD chips looking at a problem that I think I'm having with the "Chip Select" box - Chart drop down Menu - when one of the mapping chips installed is a Lake Master. Anyway, I'm seeing the same thing on my 998c SI screen when I'm changing colors BUT I'm sitting in the garage (and not on the water). Is your boat out of the water when you’re looking at your SI color issue? I see a slight backlight change when I switch between Amber 1 and Amber2. I went back to 4.970 and I observed the same backlighting scenario. I think you’re OK. If you’re seeing this SI color issue in the water, ignore all that I have said and I'll go away quietly! ::)
Take care,
Roger
Offline calli1
  • Unit(s): 1198 S I & 787c2i
« Reply #2 on: May 18, 2011, 05:58:30 PM »
This is what I am afraid of...something not right about the new update.  I did talk with the Humminbird folks today and they said the new updated program should download and work fine.  Seeing your post makes me want to hold off until I see more.  My unit is working great and I do not want to cause it any harm.  Please, anyone who has or thinking about this new update, give your thoughts.  Call HUmminbird also and see what they say.  Good luck and keep them coming.
Offline indiana 520
« Reply #3 on: May 18, 2011, 06:08:55 PM »
YEA, I`AM SITTING IN THE GARAGE AND TRYING THIS OUT IN SIMULATION MODE AND NORMAL OPERATION. SIMULATION MODE WORKS GREAT. SO FAR THIS COLOR PALLET PROBLEM IS THE ONLY THING I`VE FOUND.
« Reply #4 on: May 18, 2011, 07:04:00 PM »
Just for grins......try setting a bucket of water under the transducer and lower the ducer into the bucket.  Or what ever it takes to make the transducer wet.
See what happens then...
Offline indiana 520
« Reply #5 on: May 18, 2011, 07:44:47 PM »
before the upgrade, it didn`t matter if the transducer was in or out of the water, everything worked great. it will be friday before i can get to the water.
Offline calli1
« Reply #6 on: May 18, 2011, 08:25:57 PM »
For some unknown reasons...it seems several people have trouble downloading the updated softwares to the S I units.  Then, to make matters worse, is it the software having trouble or the downloading is not being done correctly.  The folks at Humminbird Tech told me today that they newest 5.500 updated software is fine and should not have any trouble.  I am not going to update mine yet.  What exactly does the new 5.500 software update do and would it be worth taking a chance.  I am confused ??
Offline George
  • Software: Always up todate
« Reply #7 on: May 19, 2011, 08:17:12 AM »
Calli
I down loaded and installed 5.500 update without any problems.  When installing I still follow the old practice of restoring defaults (only takes a few minutes to put everything back to my settings.  I keep a memo of changes so I do not overlook anything.
George
« Last Edit: November 03, 2011, 07:31:54 AM by George »
Offline indiana 520
« Reply #8 on: May 19, 2011, 10:13:28 AM »
i restored default setting twice. once before inserting card and again when it was completely installed.
Offline offroad
  • Unit(s): 1197/ 898
« Reply #9 on: May 19, 2011, 04:38:34 PM »
l have the same thing ...When l scroll through the color options l only have blue  We  may have a problem But maybe we dont.... l can see interfearance lines in the color that l select  but l am unable to get out on the water to test the unit...Hold the bus.... just updated my 898... same thing. l think its something to do with the color system that the units use .Stay tuned water test today
« Reply #10 on: May 19, 2011, 05:30:19 PM »
HMMMMMM....I think I will hold off a bit for the upgrade. Until we can figure out the problem...
Offline stillbear
  • Stillbear
  • Software: 5.840 5.700- 4.0
« Reply #11 on: May 19, 2011, 06:07:59 PM »
Chuck do the guys that are having issues with the new 5.500 have anything in common like are they
all interlinked do they have any accessory like weather or anything else we need to get on top of this issue
quickly is this a is-surer issue or a user issue.   Gary
« Reply #12 on: May 19, 2011, 07:14:12 PM »
Gary, Dont know, was thinking of asking the questions like you are. There has to be something common.
I know we have had interlink compatabilty issues and also standalone code issues.
I dont think HB writes the code. My belief is a vendor is contracted..
So not sure how much quality testing goes into this. Or is interlink is also tested..It does seems that a lot of issues with updates are occuring..
What is pondering is some work and some dont.  Same code same units..
OK for the guys that are having problems lets see if we can post some details of the units and what else might be connected if any.
Thanks Gary....
« Last Edit: May 19, 2011, 07:15:34 PM by sonar2000 »
Offline indiana 520
« Reply #13 on: May 19, 2011, 07:36:03 PM »
unit 1197c si  no add-ons  not inter linked with any other unit. have updated unit once before with no problems. watched video on utube before attempting down load. restored defaults once before and after download. I have contacted humminbird and they suggested restoring defaults and restarting. Tried that and no help.
Offline offroad
« Reply #14 on: May 19, 2011, 08:30:58 PM »
My unit details are  1197/ 898 Ethernet joined nothing else. And l still have yet to try it on the water with this new update. As l said before we may /may not have a problem .The only background color is blue but when l do change the color from blue to say brown l get a black background and the sonar display is brown its very hard to see because the unit is not in the water And what l am seeing is interfearance lines.... indiana 520 maybe try this turn on your trolling .motor... look at the screen do you see any lines ?Change the color tab try again You wont see much but enough to see if the color changes
Offline calli1
« Reply #15 on: May 19, 2011, 08:35:34 PM »
You folks iron out the problem or find out what is going on.  I don't think the update will do me any good either way so I'm not touching my unit right now.  Fish on!!
Offline Randeye
  • Unit(s): 1197 998
  • Software: 5.43 5.41
« Reply #16 on: May 20, 2011, 07:37:44 AM »
My 1197 and 998 are connected by Ethernet.  They were both updated yesterday and seem to work flawlessly.  Prior to the update the down/chart combo view did not work and immediately upon turning unit on screen would flash until you hit view or exit several times.  Problem resolved.  Normal si color palate.
« Reply #17 on: May 20, 2011, 11:35:08 AM »
Do not blame you Calli1....I am holding off for a while myself.
« Reply #18 on: May 20, 2011, 02:33:11 PM »
The software updates for these units are really a  moving target.
Each update usually fixes something important, but it also could possibly mess up something that used to work.  These units are doing a lot of things, and the programming for them I'm sure is very complex.
My attitude is that I'm better off doing the update because Humminbird has put it out there for one or more important reasons.  Some reasons I'm sure they won't ever tell us.
I have an 1197c SI with no interlink and my 5.500 update worked OK.
But, I did not try looking at the SI color palette yet.
When in doubt, my 2 cents says to go ahead and do the update.
Whatever they screw up on this one, it will probably be fixed in the next one. :)
If you are afraid, then keep a copy of the previous update so you can always go back.  This site has copies of older updates.
Anytime you contact HB for a unit problem, the first thing they're going to ask you is if you are running the most recent software, so it's best to keep the software  up to date.
« Last Edit: May 20, 2011, 02:38:09 PM by ITGEEK »
« Reply #19 on: May 20, 2011, 05:50:50 PM »
I understand where you are coming from Geek....but at some point in time they need to start sending quality code. Each time we dont need a new problem while fixing the old one.
Yesd we can go back in code level but why??????
This stuff should work better than it does...
HB will have to get over it as there is no reason to upgrade code if you are not having problems or do not need a new enhancement..
Offline Roddy
  • Scan,scan and rescan
« Reply #20 on: May 21, 2011, 12:19:40 AM »
I don't update until I read all post on that update plus six mo time and six phone calls to HB. Roddy
Scan,Scan and Rescan Roddy
Offline offroad
« Reply #21 on: May 21, 2011, 04:56:14 AM »
Alls fine.....  No problems on the water .Both unit performed without a hitch....
Offline indiana 520
« Reply #22 on: May 21, 2011, 03:47:09 PM »
JUST GOT BACK FROM THE LAKE AND EVERYTHING WORKED PROPERLY. SO AS FAR AS I CAN TELL THE 5.500 UPDATE IS OK. THE COLOR PALLET FOR SI IN SIMULATION MODE STILL DOESN`T WORK OTHER THAN BLUE. BUT SO WHAT.
Offline indiana 520
« Reply #23 on: May 21, 2011, 04:37:56 PM »
sorry Charles. thanks for letting me know.
« Reply #24 on: May 21, 2011, 04:46:28 PM »
Indy.... Have not considered that in a while.  I will check my 1197 and see what it does.  However I have not updated to 5.5 as yet.  So this may be apples and oranges until I upgrade.  I will see anyway..
At least is shows  you are trying out your unit...
« Reply #25 on: May 24, 2011, 04:34:32 PM »
One of the Techs here tested several units with the 5.500 software in the normal operating mode and the Simulator mode.  All had the multiple Si sonar color palettes.
« Reply #26 on: May 24, 2011, 05:08:13 PM »
OK.  What are we saying here??????...That 5.5 works....or 5.5 works in some and not others......or.....? I am a bit confused as to the compatability of the code to a unit...and selective connections to other units or applications...
« Reply #27 on: May 25, 2011, 10:00:17 AM »
Hey Chuck, consider this.
Let's say that Humminbird found out that their algorithm/code to compute depth was off by 3 feet.
Do you think they are going to tell the public that?
Heck no.
They'll just fix it in the next upgrade and be quiet about it.
That's why I always install the newest software updates.
We just don't know for sure what it fixed, but I go on faith that my unit will be better because of the update.
« Last Edit: May 25, 2011, 10:01:24 AM by ITGEEK »
« Reply #28 on: May 25, 2011, 06:56:40 PM »
ITGeek......We expect that but as you can see by the posts here that the new code does not always work....code does get shipped with defect...I hope not by choice but by error in testing.
What some of the folks here are an experience in code that does not work for them because of...???????.....meaning that it was not tested fully before shipping.
We all know that new code is suspect today in any capacity be it sonar, computer, tv.....anything that employees an internal processor...
So the caution is dont always be the first to install. If a forum has posting of upgrade problems dont install until you see satisfactory acceptance of the code.
blind install could mean you get impaced by a defect.
I also maintain that quality control should produce error free code but it doesnt. So lets go with the caution view...
As to why code is updated I think the user has the right to know what the changes are.
« Last Edit: May 27, 2011, 12:15:50 PM by sonar2000 »
« Reply #29 on: May 27, 2011, 09:57:10 AM »
I  had the new update on the water and it worked flawlessly.
But, when trying to look at a sonar recording, it seems the playback is really slow.  I tried all 3 of the forward playback speeds and they are all slower than normal.
« Reply #30 on: May 27, 2011, 12:18:27 PM »
Yep...I felt the playback speed did not have enough speed control.  One of the reason for using an external viewer. I wonder if this may have to do with the sd card size or type of manufacture.
I have not tried a new extreme card.  What card do you use..??
« Last Edit: May 27, 2011, 04:34:24 PM by sonar2000 »
« Reply #31 on: May 27, 2011, 01:07:13 PM »
I have a Sandisk Extreme III.
I think the playback speeds were OK in previous software versions.
I just noticed after updating to 5.500, it seemed like it took forever for anything on any screen to move.  Going to the faster playback speeds didn't seem to make any difference at all.
My cpu was replaced recently and everything else is working perfectly.
Must be a software glitch.
I've tried the Humviewer.
The SI images are great but the 2-D don't look so good.
Do you know of a better viewer for 2-D?
Thanks in advance.
« Last Edit: May 27, 2011, 01:14:17 PM by ITGEEK »
« Reply #32 on: May 27, 2011, 04:38:09 PM »
Yep, I was afraid you were going to say you had the bigger and newer card.  HMMMMM...it is probably the code.
Or you asking for 2D or DI.
Something I tried that works somewhat is the converter to the lowrance viewer and with a bit of eyeball adjustment it seems to show a pretty good 2D image...
Offline Scrutch
  • Mikey, my son, the Captain
  • Unit(s): 1198c si, AS 360 imaging
  • Software: 6.74
  • Accessories: AS WX1 Xm weather
« Reply #33 on: May 28, 2011, 10:58:24 PM »
Sat down to do the upgrade and saw this post.  I think I'll wait till you all give the all clear.
Offline calli1
« Reply #34 on: May 29, 2011, 08:44:47 AM »
I agree.....won't be updating my unit anytime very soon.  This all has to be worked out.  I will wait until someone on here says it is ok.
« Reply #35 on: May 29, 2011, 08:51:23 AM »
I agree....I put the 5.5 on last night but was very careful to restore defaults, turn unit on, insert card and then wait patiently until the green all ok screen came up.
So far so good.
Unless you are in a big hurry I would wait until all the posts and issues have been remedied.
We put the update on just to see if there were any concerns. We have a backup unit just in case. And an airplane so if we need plant assistance we can just fly down...
Now we dont have any interlink or ethernet items so just the base unit.
Offline George
« Reply #36 on: May 29, 2011, 01:56:18 PM »
Since you lost the interlink and ethernet with the latest update have you tried reinstalling the previous update to see if they have been restored (just curious)?
George
« Reply #37 on: May 29, 2011, 03:31:51 PM »
George, just a poor post on our part.  We dont use the interlink or the ethernet.. ;D.... ::)
Thanks, Chuck
Offline Kenosha
  • Unit(s): HB 898
« Reply #38 on: May 30, 2011, 08:37:33 AM »
I updated my 898 C SI to 5.5 and the sonar screen is different than it was and the recording and play back was slow,jerky and the screen has a flicker. I put the 5.210 back in and all worked fine. So there is something wrong with 5.5 upgrade.
« Reply #39 on: May 30, 2011, 09:36:47 AM »
According to this forum there is something wrong.
It seems that different guys have different problems, and then again some experience the same.
We put 5.5 on yesterday and now need to do a water check out.  So far the static checkout on the bench is working.
Playback seems slow.
I will watch for the recording speed on the water.
Chuckj
Offline stillbear
  • Stillbear
« Reply #40 on: May 30, 2011, 01:47:48 PM »
Chuck it's got me thinking are the people having trouble with updates putting there updates in while there unit
is hooked up on the boat with the transducer,weather , etc. or are they doing there update on a bench like i do with nothing else hooked up to the head but a power supply.Plus I always take my SD cards out before I update. Gary
« Reply #41 on: May 30, 2011, 01:52:11 PM »
Gary, I just dont know. some of it may be just as you said, but for others it may be a compatability issue between units..Not sure the code was tested out completely..
Offline stillbear
  • Stillbear
« Reply #42 on: May 30, 2011, 07:00:44 PM »
Chuck i was trying to simulate 520 issue the only way i can make the screen stay blue in simulation
mode on side imaging is to go menu, menu go to sonar curser down to color and it won't change
exit out. Screen still on SI hit menu cursor down to color walla they ALL work. Gary
« Last Edit: May 30, 2011, 07:10:48 PM by stillbear »
« Reply #43 on: May 30, 2011, 07:48:49 PM »
Heckfire Gary.  I guess we might as well write a new handbook (manual)  ;D
« Reply #44 on: June 01, 2011, 11:02:40 AM »
Gary,
I am not understanding your button sequence to get this to happen.  Could you explain it better, step by step please.  As read: if you press the MENU button twice than it puts you into the main menu system.  There are no menus to change the Si Colors in the main menu system - this is under the X-Press menus for the Si sonar.
Offline stillbear
  • Stillbear
« Reply #45 on: June 01, 2011, 08:18:32 PM »
Greg just like I stated I was trying to help 520 out with his new update or whatever and i was telling Sonar the only way I could get my 1198 to stay on blue was from the sonar menu not the menu from SI Greg I put that out there for 520 I
don't know where or what he was doing or what the unit was on . If you read what I wrote you can see I gave him
two different examples . Just trying to help.  Gary
« Last Edit: June 01, 2011, 08:27:59 PM by stillbear »
Offline calli1
« Reply #46 on: July 10, 2011, 09:42:54 AM »
Have you downlaoded the newest 5.5 software yet Chuck.  I think I'm about to.
« Reply #47 on: July 10, 2011, 04:08:26 PM »
Calli1.  I finally loaded the 5.5 software. It works fine.  but then again I dont interlink or ethernet link.
As a stand alone 1197 5.5 work fine...
Offline calli1
« Reply #48 on: July 10, 2011, 04:34:22 PM »
Thanks.....I do not ethernet either.  I have a 787c2i and my 1198.  I am about to do my downloads today.
Offline ncpsddiver
  • Unit(s): 1197
  • Software: 5.5
« Reply #49 on: August 08, 2011, 09:20:43 PM »
Hi guys, My team is new to this forum so bare with me. I notice that there have been a lot of download issues with the 5.5 version in the previous replies. We have a 1197 and love it. I was told about the update so I downloaded it to my SD card but have not installed it on the unit yet. I'll have to say...I'm a little nervous after reading all these post. Have the issues been resolved yet? I'll believe I will just hold off for a while. Thanks
Lt. Ellis
Last post February 09, 2011, 05:46:23 PM
Last post February 16, 2011, 07:38:25 PM
by stillbear
Last post July 23, 2011, 11:44:12 AM
by stillbear
Last post August 16, 2011, 09:01:45 AM
Last post April 25, 2012, 07:37:05 PM
Last post March 11, 2013, 12:04:10 PM
Last post March 25, 2013, 03:48:57 PM
by strawdg
Last post March 30, 2013, 12:56:34 PM
