Author Topic: 1197 update..  (Read 8656 times)
Offline jseasor
  • Trying to learn as much as possible about SI
  • Unit(s): 1197C SI
  • Accessories: 1197SI
1197 update..
« on: February 07, 2011, 05:16:18 PM »
just getting ready for spring and wanted to check on any updates available.  looks like there is an update for my Humminbird PC as of jan. 2011 and an update for my 1197 as of jan. 2011.  what are these updates and how do they effect HB PC and the 1197? thanks
Re: 1197 update..
« Reply #1 on: February 08, 2011, 01:41:08 PM »
The updates are for fixing known problems and to give users more options/features.
The ultimate goal of the updates is to make things work better.
Some people have had problems updating.
I don't use Humminbird PC, but I have updated my 1197 five times without any problems (so far), and I am getting ready for the 6th update.
My reasoning for doing the updates is if HB has gone through the trouble of putting up a new update, it must be pretty important.
It may even make the system more accurate.
If you search on the HB site, it will tell you what a particular update affects.
The only problem with the updates is that you are supposed to set everything to factory defaults, do the update, then set everything to factory defaults again.  If you ever went through the menus and set custom settings for yourself, you will have to go through the menus again and do it all over again (and for every update afterwards).  But, I figure it's a necessary evil if I want to have the newest software for my machine.  And the good news is that the updates are absolutely free.
Good Luck.
Re: 1197 update..
« Reply #2 on: February 08, 2011, 04:23:09 PM »
I haven’t heard what the changes to HumminbirdPC were for so it must be pretty secret.  ::)
Re: 1197 update..
« Reply #3 on: February 08, 2011, 04:25:54 PM »
I was on the HB site but could not find the specifics of what an update did.  can you give more detail on the site selection....
Chuck...
Re: 1197 update..
« Reply #4 on: February 09, 2011, 07:43:58 AM »
I found some information in the Frequently asked questions under support.
You could also email Humminbird and ask about a specific update.
Re: 1197 update..
« Reply #5 on: February 09, 2011, 05:46:23 PM »
Thanks.....chuck....will try same
Last post August 07, 2009, 12:13:35 AM
Last post December 31, 2009, 01:28:15 AM
by videorov
Last post January 12, 2010, 01:36:17 PM
by keizerh
Last post February 22, 2011, 07:58:34 AM
Last post February 28, 2011, 05:19:09 PM
Last post March 11, 2013, 12:04:10 PM
Last post March 25, 2013, 03:48:57 PM
by strawdg
Last post March 30, 2013, 12:56:34 PM
